nitto 555R drag radials
i am look'n for some new tires. i was considering the bf goodrich g-force t/a kd's or the nitto 555r's. i was at a local tire store and they said they just had a guy w/ a vette put em on and they heard back from him and it made .30 differnce in his 1/4 times. so lets say i'd be run'n a 14.2 instead of a 14.5, can the nittos make that kind of a differnce?
It does make a difference. I was running 14.20's with 2.2 60 ft. times. I put on a set of Nitto drags and ran 14.00. And that is only one pass on the tires. I pulled a 2.07 60 ft. with them at 15 pounds of air. I think they will do even better than that. They are definately worth the money. I would buy them. Are you running a 350 or a 305?
i got the 305 w/ 5-speed, it keeps up w/ 350's. tonight i just beat a 90 z28. i got some stuff done to my car as u can see in the signature below. but do u guys recommend the nitto's then? i haven't heard anything bad about them yet.
If you don't have any traction problems on street tires than they won't make any difference. If however you are not hooking up then yes the Nitto's will hook you up and reduce your 60ft and 1/4 mile times.
Bob
Bob
1 Post
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Originally posted by BadBowtie88
I would go with the Nitto's man. Go to discount tire direct.com and buy them. For two tires shipped by ground, the total cost was $172.31. But, the price is well worth it.
Originally posted by chevy power
oh, i have problems w/ traction. theyspin through 3rd. the tires i have now are super bad though, no tread.
I managed to pull a best 60 ft of 1.79 when I had a different convertor on the Nitto's. You should like them.
Bob
