my new "ss" hood
my new "ss" hood
Well, here it is....I just recieved it today and figured I'd put it on to make sure it fit right before painting. I think it looks mighty nice and was well worth the $. I'm also proud to say I've got the first one in town, what do you guys think?
~darbster~
~darbster~
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I can't see spending $400 on a hood + at least $200 on paint because it 'looks cool'. Fact is - its not functional. Then again - I hate the louvers on the IROCs and the blisters on the 91-92s. Its just ornamentation and serves no purpose. It says "Hey - look at me! I think I'm cool". At least with a cowl hood there is a purpose - using the high pressure air at the cowl to cool the engine bay and remove heat. I don't mean to rain on your parade - just expressing my opinion. SLP made a great call when they introduced these hoods as functional on the 4th gens. Non-functional hoods are a farse and come close to being rice.
Weight reduction is the common excuse. @25lbs from the frontend. Cool. But, its like a ***** putting on a carbon fiber hood and driving around town.
Tim
Tim
Car: 87 IROC-Z
Engine: 427 SBC
Transmission: MDP T56
Boy..isnt that the POT calling the Kettle black!!!
Whats up w/ those "shiney" valve covers... ?? Shudda just kept your original ones... LOL
Rick
![Roll Eyes (Sarcastic)](https://www.thirdgen.org/forums/images/smilies/rolleyes.gif)
Rick
1 Post
Car: 2000 Trans Am
Hey I've heard of people cutting out the scoop and making it functional.
You think If I took some old seat foam, sprayed some WD40 in it and put it in the opening and secured it with zip ties through some drilled holes in the SS cowl, it would be worth 30 RWHP?
![Confused](https://www.thirdgen.org/forums/images/smilies/confused.gif)
![doh](https://www.thirdgen.org/forums/images/smilies/doh.gif)
Car: 1985 Trans Am
Axle/Gears: 3.70
I disagree Trax. Ain't nothing wrong with making you car look good. What's the point in having a car that looks just like the other 200,000 built just like it? If you can make the hood somewhat functional even more bonus points.
Supporter/Moderator
Trax,
I'll be waiting to see your Camaro without the ground effects and not have any kind of wing or spoiler on the back. Hey - it's less frontal area, so you'll have a faster top end too!
He he he.
A.
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
A.
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
Guest
Posts: n/a
I have to disagree with you Trax. If appearance really didnt matter and all you wanted was function, wouldnt you be driving a Mustang instead?
As for the hood, dont really like it. Of course its better than the lame late ram-air TA style hood I saw on a Camaro, that really looked stupid.
But they CAN be functional...I have my air cleaner height set to where cool air blows straight onto the filter. Also by doing a little trimming on the back part of the cowl, you can make use of the low pressure area as well...plus it lookers meaner than H3ll...a lot better than any 2" cowl induction hood in my opinion. Guess I should remove my rear seats since they aren't "functional"...they are just adding more weight to my "*****" IROC! I suppose the 91-92 Z28 high-rise spoilers are "*****" as well? Man.......I need to get a "Powered by VTEC" sticker for my Camaro.
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
Tim
Tim
1 Post
Car: 91 Red Sled
Maybe I'm mistaken but doesn't the SS hood have the same cowl effect as a standard cowl hood? Look at the back where it comes to the firewall. Looks just like a standard 2.5" cowl hood to me
It's been talked about before but the actual SS hoods being functional is a joke all together. Even if it was completely open, it's still too low profile to pick up any "useful" air. Why do you think all snorkels on drag cars stick up OFF the surface of the hood. You're probably making it harder for the car to breath if you just had it sucking through that front slit they call an opening.
Looks bad *** but I'd block it off and use the cowl effect!
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
The funny thing is ... I was joking about this whole thing. I was bored and wanted to see what people's responses would be. Sometimes I get frisky. This is one of those times. I like the 'SS' hood ... roflmfao.
My only disagreement here is hood weight. Along with a couple others we weighed a stock hood vs. a fiberglass hood. The difference was 26lb for a hood with hinges/latch. You wouldn't save 40lb unless you pinned it on.
SS Hoods are a nice addition. They look mean and IMHO improve the look of your thirdgen.
Tim
Tim
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
you do get another 2.5 inch of clearance space and is does have a small cooling effect when you put the hood on..
Interesting.
I needed my hood, because I could not shut the stock hood with what I had.
It weighs a lot less than the stock hood, I had a clearance issure, and I want cold air induction. Right now, it is functional and serves a purpose. I could not use my stock hood at all.
I can make the RamAir functional as well, and that will be done in the near future. I am wondering why he said that the RamAir hood can't be made functional when it can?
Nothing bogus about it.
![Cool](https://www.thirdgen.org/forums/images/smilies/cool.gif)
Car: 1987 IROC-Z
Engine: Carbed 355
Transmission: TH-350
Hey IROCZTWENTYGR8,
me and my dad are in the middle of making my iroc hood functional. we took the louvers off and cut the metal plates under the louver of and are trying to fabricate the louvers so that they will be open but still have that stock look. so far it seems like it will work ill post picks when i am done.
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
I wonder if you could hook it to the throttle cable to activate the louvers.
example, for a carb setup, mash it far enough for the secondaries to open, hot air jumps out.
Car: 1987 IROC-Z
Engine: Carbed 355
ya guys that is the problem with the idea of opening the top of the hood like that. i was wondering if i any of you guys know anything about the cross fire injection. did those have a hood that open a closed with the throttle or am i thinking of somthing else. maybe i can find an idea with those. thanks
yeah my dad has a CFI engine on his 83z and those louvers did open once you jammed the throttle....cool as hell.....i wanna steel it paint it black and put it on my 88 camaro which has open KN. Would serve a better purpose!!!
Car: 1988 Medium Orange Metallic IROC
Transmission: 700R4 transgo shift kit
Axle/Gears: 4.10 in box lol
looks like Ill be getting a new hood soon too...
never let anyone else shut your hood...
I usually dont cuz you have to let it down...hold the latch in and close...
well the other day...i was replacing the tail lights and letting the engine cool (hood up)
as i got closer to finishing the lights...my girl says.."i closed the hood for ya"
I kind of glance up and see its down and figured she shut ti all the way...
well I fu=inished the tail light and went in for dinner....it was dark now and i totally forgot to check the hood...and we went for a drive....
well i turn right out on to the road and not 10- seconds into the drive....wham! the hood flies upI slow her down quickly and throw the 4 ways on...good thing there wasnt alot of traffic.
the hood was straight up....no longer slightly curved...a flat hood.
the hingrees are all bent to...I was furious of course.
least it didnt hit the windshield. and a lot better than my hood on my 89 firebird which flew right off the car twice...hit the grass once and was ok...second time it hit the road and bent in two...no luck with hoods im tellin ya![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
:lala:
![Frown](https://www.thirdgen.org/forums/images/smilies/frown.gif)
:lala:
Car: 2000 astro
Engine: 4.3
Transmission: A4
I believe the crossfires used an electric solenoid to open the flaps, much like the old camaros and chevelles with cowl induction.
91TTOPZ
Exterior Parts for Sale
09-20-2016 12:42 PM
