BFG Comp T/A's vs. Pep Boys Ultra Z's.....
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Has any1 had both on their car?? The BFG's are much more than the Ultra Z's and I would like to know how much better the BFG's really are, since every1 that had Ultra Z's said they are good, if u should pay more for the T/A's or get the Ultra Z's. Thanks!!
Looking For:
87 IROC-Z 350 TPI
84 TRANS AM 305 H.O.
Looking For:
87 IROC-Z 350 TPI
Administrator
I want to compare just BFG's and Ultra Z's by people who have actually had both. Also, which is better for the money and in all areas of performance.
Looking For:
87 IROC-Z 350 TPI
[This message has been edited by IROCZTWENTYGR8 (edited January 09, 2001).]
Looking For:
87 IROC-Z 350 TPI
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
I actually have both on my car right now. I have 1 Ultra Z on my rear cause i blew out on of my comps. They are both decet tires, but the comps hook better on hot dry pavement. They both suck *** in snow though.
I have had some really bad experiences with pep boys tires, I had to replace 3 out of 4 on my wifes car over a perioc of 4 mos after I bought them due to 2 knots and one was out of round.
Administrator
Did u let Pep Boys put them on??
Looking For:
87 IROC-Z 350 TPI
Looking For:
87 IROC-Z 350 TPI
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I have had horribile service with pep boys. There were driven out of our county in flint they were so bad. I had them put on my tires and it took them 4 hours!!! I figured, well they must have been just busy. So I go back there for a flush and fill. Took them 5 hours!!! and some fat a$$ mechanic drove my car out and said "here u go" I sat in my seat and it feel completly backwards! They broke my seat and weren't even goona tell me! Needless to say, I will never go there for anything ever again.
Eric Natzke
91 Firebird 305 TBI
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-180 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-MSD Cap & Rotor-MSD Blaster Coil-Rapidfire Plugs-265/50/R15 Tires-Emmison's all Gone-Free TBI mods
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Eric Natzke
91 Firebird 305 TBI
I personally would go with the comp ta's
I had my license taken from me on aug 10 1996 and will be getting it back on feb 19 2001(habitual offender(drive to fast)) and my 84 Z-28 had comp ta's put on it in 1994 and was drove hard from 1994 to 1996 and she has sat since aug 10 1996 and the tires have never went flat(it is kept outside). The ability to maintain air pressure really impressed me so they are the only tire I will buy from now on.
1984 Z-28,1984 TRANS-AM,1985 firebird,1986 firebird,1988 IROC-Z, 1985 fiero gt, 1986 fiero gt and unfortunatly an 84 bronco
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I usually tend to get the cheapest. Mine tend to smoke rather a lot and so need replacing every couple of thousand miles
Rob
1987 IROC-Z Auto (LB9)
Black/grey with the stance of a streetfighter
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat.
Future mods:
K&Ns
RAM Air
New Underdrive pulleys-either March performance pulleys or Auto Specialties Performance
Air foil
Rob
Mods
Future mods:
K&Ns
RAM Air
Air foil
The pep boys ulta z's that came on my car when I bought it weren't the highest quality tire on the market, I was pretty un=happy with them. My friend however had a set of BFG Radial TAs on his car, and they were wonderful tires, so I am sure the comp TAs are the even better!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.6:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Gutted Catalytic Converter, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, Ported TPI Plenum and Base, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
L98 TPI 350 (5.7L)
Go with re730's they are only $114 a piece from the tire rack. Most any tire dealer will match prices or quote you a little higher and include mount and balance. I've had SP8000's and RE730's, and I like the re's much better in all aspects; plus you get rim protection with the re's.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
taliesian:
2 things- Cool name, I've seen it before, Where did you get it? And two, the ability to hold air over that time is more a function of the wheel and how well it seals to the tire, not the tire holding air.
BTW, Comp T/A's are excellent. Love them.
Bob '89 Formula CC350
Last(lost)Member of the Elusive Great Lakes Crew
My car's homepage
My car's homepage
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
NITTO 450's
91 Z28 5.7l Camaro
T-56, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
91 Z28 5.7l Camaro
more to come....
My 91 Z28
no green
01-09-2016 09:22 PM
