Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Founders strut tower mounts
Old 09-24-2019, 03:21 PM
  #51
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Founders strut tower mounts
I can't even imagine how the Founder stuff would be more difficult. It operates the exact same way with the addition of the caster adjustment, which you could just lock in a set position to get fine adjustment later.
Old 10-09-2019, 08:28 AM
  #52
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
Mine have been moved around the garage multiple times and have no signs of any damage to the powder coat.
Originally Posted by scooter
LMAO, it's not epoxy, there is no "cure time" for PC
Yes, there is. Powder coat is cured at a certain temperature for a certain amount of time which is dependent on the manufacturer of the powder.
Old 10-09-2019, 09:19 AM
  #53
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
NM.
Old 11-26-2019, 07:27 AM
  #54
Sdmodified's Avatar
Car: 1991 Camaro RS
Engine: LS3 w/ HCI
Transmission: Magnum F (T56)
Axle/Gears: 4th gen 3:42 posi rear
I installed these in the spring and drove the car all summer. Part of an entire suspension refresh. Also used Founders Rear control arms with relocation brackets, pan hard bar, and wonder bar. For the price of these mounts from other companies, I almost went stock replacement, but then found the founders ones and it was a no brainer to try theirs. Glad I did and all their parts have been quality.
My car drive so planted and tight now, amazing what refreshing 30 year old parts can do, especially with quality parts from these guys. Their parts are also priced better than other companies so that’s a plus! I am about to order their Torque Arm next, then unfortunately I think I will have everything I can use from them...
Wish they made sway bars and/or a strut tower brace.
Old 11-26-2019, 07:58 AM
  #55
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
I have their castor plates/ strut tower mounts, panhardbar, and rear trailing arms as well. Money well spent
Sdmodified (01-15-2020)
OddJack
09-06-2012 01:34 PM
Anomaly
Aftermarket Vendor Review
06-05-2010 10:01 AM
88fastgta
05-24-2010 05:58 PM
formul8!!
12-06-2002 11:36 AM
Quick Reply: Founders strut tower mounts
