NOS tpi 150 plate system?
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
IF you have this do you like it ???
any problems or just all smiles?
just curious as to any horror stories before I buy one..
thanks for any help.
88 WS6 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
free mods, dynomax exh, urethane motor+trans mounts,
SSM frame con, Bilsteins
very trick homemade ramair, Accel 300+ ignition system.
http://www.geocities.com/transam617
I love it I had it on the 305 and it backfired once. Made a nice piece of art work out of the maf. I now have a purge and dont have that problem with the 383.
87z 383,afr 190's, crane hyd roller(224/230-.509/.528,112 sep),Ported and polished mini ram, 30lb inj, 3.42 gears, strange 12 bolt, tremec 5spd, , 1,3/4" slp headers.
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Ive got it. The last time I used it I ran a 13.19 @ 104.4 mph with my mostly stock 305, jetted for the 100 hp. Worked great for me. No troubles.
Convertible, L98, Mini-ram, ZZ9 cam, Comp Cams 1.52/1.6 steel roller rockers, Trick Flow 23* heads, K&N's with chopped airboxes, March underdive pulleys, Edelbrock ceramic coated TES, Flowmaster cat-back exhaust, Dynomax high flow converter, MAC subframe connectors, Accel box & coil, 3.23 rear gears, white face gagues, and NOS!
When I get back from Kosovo I will be installing these on-order items!
1992 Trans Am
05-10-2023 07:19 PM
92firebirdchris
Exterior Parts for Sale
08-14-2015 11:56 AM
Sanjay
08-12-2015 03:41 PM
