What's your dizzy???
Car: 1990 gta
Engine: 5.7 l 350 v8
Transmission: automatic
Hey all,
I have a 5.7 chevy 350 tpi and was wondering what kind of distributors people have.
My stock one was giving me trouble so I have an aftermarket reman from
advance auto parts.
It works but I want something a little better and I need some ideas.
Help???
craig
advance auto parts.
Help???
craig
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: What's your dizzy???
I swapped out ECM's and am using F.A.S.T with the Dual Synch Distro
http://www.compperformancegroupstore...Code=DistChevy
Car: 1990 gta
For the most part I am going to keep it stock.
Eventually I will put a better intake and headers on there but other than
that nothing major to "supe" it up.
How much extra was the ecm for that distibutor?
This is what I have
http://www.summitracing.com/parts/ms...make/chevrolet
It's plug and play.
Although, I have a digital 6+ ignition box.
It's plug and play.
Car: 1987 IROC-Z
Mine was a little more expensive but necessary for what I needed at $1900 for the just the ecm without the Dizzy.. I wanted 16 injector control with internal datalogging though
http://www.compperformancegroupstore...ineControlUnit
if you swap dizzys be sure to swap the gear to the diz going in or you can go wit a poly gear and not worry bout it.
the shaft on your stock diz is .428 and most shafts are .490.
im running performance distributors DUI and like it fine. dosent hurt they are local and can custom curve the unit to your app.
junkcltr
08-02-2019 11:12 PM
school boy
10-22-2015 11:47 AM
