What do you think of the new rims/stance?
Car: 1991 Camaro RS/1989 Formula
Engine: 5.0 L03 V8
Not the best pictures but you get the idea, these are the American Racing Torq Thrust II's. At first I thought the back tires stuck out too far but now I think I like it. Before anyone says anything I know my car is filthy, its been washed since these were taken.
Re: What do you think of the new rims/stance?
I like it. What rear end do you have?
Engine: 5.0 L03 V8
Sorry I'm not sure what you mean
1 Post
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
I usually don't care for them but on your white car they look damn nice! What size tire are you running?
Engine: 5.0 L03 V8
Thanks! They're 275/40 in the back and 245/45 in the front, I went with 17's because you couldn't get 275's for 16's
Car: 1984 z28
Engine: 5.0 HO
Are those the wheel and tire combos I see on eBay? Are they the 17"? I want them for my '84Z and I plan on dropping an inch or two.
Bob
Bob
Engine: 5.0 L03 V8
I got them through Belle Tire because they carry American Racing products I had them special ordered. They are 17's though.
Sorry el phone typo, I meant what rear end do you have? Stock 4th gen or other?
Engine: 5.0 L03 V8
Its cool I figured thats what happened but I still have the stock 3rd gen rear end
Car: 1984 z28
Engine: 5.0 HO
AM. Racing 17x8/17x9 Chrome Wheels Rims Tires 245/45ZR17-275/40ZR17
$1500 shipped
Nice ride you have. I love clean Camaros.
Engine: 5.0 L03 V8
Thank you! Those rims look chrome and mine are actually polished aluminum but they're two very similar finishes, also different brand of tires but this would give you the same look. I believe mine are offset -10 so check that before you buy because they come in a few different offsets.
Engine: 5.0 L03 V8
Haha I know, I'm just hoping the tires don't hit my paint with rocks because they're out so wide.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Very nice indeed . I Like the slight rake with those wheels.IMO a car set up in this manner should not be lowered.If there was any more space between the tires and well than I would say yes to a little drop to get them just where they are now.Would you tell us how wide the wheels are.(7",8",10" ??)
very nice fit and stance. i like the look.
Car: 82 El Camino
Engine: built 355
Transmission: T-56 upgraded internal
Axle/Gears: 10 bolt 3.42
Nice looking camaro.
Drop it......I had the same Torque Thrust IIs (now for sale) 17x8 as im betting yours are with both Eagle F1s and Nitto NT555s at 275-40-17 in the rear, dropped mine an inch all around with vogtland springs and never had any problems with rocks chipping the paint outside of the fender wells. It also kept the slightly raked look that I liked.
Posted from Thirdgen.org App for Android
Car: 1983 z28 Crossfire
Engine: V8
Very Nice... Have u had thoughts about raising it a few inches? ive been thing about raising mine but i like how it handles now. but with the wider tires i feel like i should raise it.
Car: 83 camaro berlinetta
Engine: 40 over 350
Transmission: 86 T5
Man, the stance, and look of the wheels are nice but the rears stick out way too far. I would definitely return them and get the correct backspacing. Your first reaction is the give away. You don't want to get used to the look, you want to see your car and automatically say "SWEET". Don't let the dudes with bad taste sway you.
P.S. when someday if you want to lower your car, they'll look even worse, not to mention there is no possible way to achieve decent suspension travel when your quarter panels are hitting/rubbing on the top of your tire.
1 Post
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Car: 91 formula
Engine: 350 tuned port. bolt ons
i love the wheels. in fact got them on my formula with a 373 rear. it sticks out alittle but looks good. Mine are from american racing first gen ones. the look diffrent then yours.
Car: 82 El Camino
Engine: built 355
Rybread11
I suggest doing a search on suspensions before posting erroneous information that is merely your opinion.
With the tires and rims he is running which look F'N SWEET lowering would not be a problem, nor would suspension travel........ Out of the 13 3rd gens i've owned 11 have been lowered between 1"-2.5" with the widest tires in the rear I could fit.
White1991rs......think it looks great. Are your tires sitting outside the wheel well by about an inch in the rear? I have the American Racing Daytona 18's with 255/40 Z18 Bridgestones. I am just at the lip with a "0" offset. I am thinking of dropping it for sure. I would double check with clearance with a +10 offset and a 275/40-18 tire. Good Luck. We have the same car, however mine is soon to be a long way from white.
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Looks like mine except i have CraggerSS wheels. Looks good.
Car: 1989 SS
The backspacing is a non issue considering we are sporting a 4th gen 10bolt. It has a drag stance that 90% of people like.
Lol i just reread and you still have the stock 3rd gen rearend? That's to much man. Never think about going 4th gen rear with those wheels. Granted it looks good but my wheels tucked with my 3rdgen rear stock.
Engine: 40 over 350
Transmission: 86 T5
Rybread11
Disregarding the above, after looking at it again, is it possible your rims are mounted incorrectly? It looks like they may be switched front to back and side to side, with the front tires mounted on the rear wheels and the rear tires mounted on the front wheels. That is if you have a different offset on two of the rims (which it looks like you do in your pics). If your rims are all the same size you could swap them around and see if it looks right. You would have to turn the tires around on the rims though to have the tread pattern going in the right direction.
1 Post
You need to read my post again. First, he is specifically asking for our opinion's in the title he created for this thread. Second, "Don't let the dudes with bad taste influence you" is a statement I made regarding his choice in rims, and speaks to the question of backspacing, which he infers (according to his taste) is the questionable aspect of the wheels.
I dont lke it. Looks like someone put 3rd gen wheels on a 4th gen rear. Not really a good look. The fact that it's 275 width tires helps it a little, but still its a little too much. Drag stance... most drag racers are trying to tuck huge meats as far as possible, so they may stick out a bit, but they're very wide. They also generally use 15 inch wheels. Youre mixing a modern pro-tour look and a cheesy rendition of the 70's-80's pro stock look into the same car. If you like it thats all that matters, but I agree with the other guy, if your first impression is that it doesnt look right, then it doesnt look right. None of us here are seeing the car in person - you are. There's a chance the look might fix itself if you lowered the car... but Im not sure. If you want a rake and rear tires that stick out, then run 15 inch wheels.
Also, your tires are on backwards in the first picture. Im guessing you noticed since its fixed in the rest of them?
BTW, you have a gorgeous car.
Engine: 40 over 350
Transmission: 86 T5
I wrote what I did, to offer advice to the person who started this thread, not to tell other people what I think of them. If you want to take it that way, I think you are being too sensitive.
Car: 1983 Z28
Engine: Forged 355
They don't look too bad, almost look like 18's though
Engine: 5.0 L03 V8
Engine: 5.0 L03 V8
I haven't put much thought into raising it, I'm not sure about that look, if you end up doing it you should post pictures
Engine: 5.0 L03 V8
Engine: 5.0 L03 V8
#42
Engine: 5.0 L03 V8
Rybread11
#43
Car: 1989 SS
#46
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
I am not a big fan of the offset on the rears but I always say if you like it then that's ultimately what matters. Enjoy the new rims and stance.
#47
Car: 1989 SS
Your right, everyone want's to know why 4gh gen fbody's are heavier, well there you go.
#48
Engine: 5.0 L03 V8
Thanks! Im pretty happy with it now but Im a little bummed because I dont know what Im going to do about beefing up the rear end with out pushing the wheels out more :/
#49
Anyway, you can always have a narrower rear end made by Moser etc.
#50
Engine: 5.0 L03 V8
I didnt know that. I dont need anymore width but I'd like a little more strength because Im not going to be running the 305 forever.
