Cyberdyne's calibration box & GM T-56
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
I had talked to Cyberdyne about a month ago and was told that the calibration box that Jegs sells was NOT recommened for any GM vehicle. So who has this box in their car and are you having any problems with it? Also, is there anyone out there using the box with a T-56 tranny and a 90-92 Camaro stock speedometer? are you having any problems, where you able to use the calibration box to make the VSS signal work with the stock speedometer and ECM?.....
Car: 1991 Camaro Z28
I have a '91 Z28 w/ T56 and the Cyberdyne box. It works fine for me. You'll probably never get the speedo 100% accurate but you can get it really close. I do notice that occasionally it will lose its accuracy so all I have to do is adjust it again. That's a minor problem though, for me at least.
Hmmm...I've never heard of the Dakota Digital boxes before. How much do they cost and where can I get one? Does it hook up the same way as the Cyberdyne box?
1991 Z28 - 350 TPI, T56, McLeod street clutch, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, no cats, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Steve Spohn adjustable torque arm and T56 crossmember
Engine: 409 SR
Steve,
Go to www.dakotadigital.com and look in the accessory menu and then click 'speedometer interface'. Its the same price as the cyberdyne from Jegs. You can't beat the one from Dakota....can't wait for it to get here.
HTH
HTH
I called dakota to inquire about the SGI-5 today and was told we needed to know the Pulse per mile rate of our electric speed sensor...If any one knows how or where to get these figures I would appreciate it before I order one
http://www.jagsthatrun.com/Pages/Spe...eedometer.html
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
