Line - locks....
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
Line - locks....
Anyone have one? And which brands do you recommended?
Can you guys list some good things and bad things about them.....
Sportsman II 72 CC heads, Pete Jackson gear drive, Performance Resources chip, Edelbrock 1 5/8" headers and Edelbrock cat back exhaust, hi-flow cats, Trans-go stage 3 shift kit, Vigilante 9.5" 2800 stall convertor, SLP cold air induction, SLP roller camshaft, 24lb ADS injectors, AFPR, 3.45 rear end gears, and other goodies...
http://members.aol.com/jwnolte/raven.htm
oh one thing i forgot to say. if your car is like mine you'll run into a problem getting the factory flare nuts on the brake line to thread into the ling lock parts. i had to run new lines for the front brakes so i could use the line lock. the plus side is my brake lines are neater and cleaner looking now that i rerouted them.
I had very bad luck with the B&M one. It would just not hold the car back at all. The Hurst one is superior in my opinion. You probably will run into a problem with the threads matching up though because one is standard and one is metric. However, I remember seeing a kit from Mr. Gasket that solved that problem.
I personally just refitted the existing lines with the different fittings and reflared. Looks good though.
Good luck
Steve
Good luck
Steve
