stock 305 after market parts
Car: 1984 Trans-Am
Hi Everyone,
I recently purchased a 1984 trans am with a 305 ho. After reading some articles and hearing everyone rip on the 305 i decided to build mine up. So i just wanted to get everyone's opinion on these parts with the 305. To be honest i do not understand a lot about cfm, comparison ratio, port size or anything to technical. I understand the basics of a car and how to work a wrench. Any help with these parts or what i should buy would be very much appreciated. Thank you.
http://www.jegs.com/i/GM-Performance...060K1/10002/-1
http://www.jegs.com/i/Comp-Cams/249/CL12-242-2/10002/-1
http://www.jegs.com/i/Hooker-Headers/520/2460/10002/-1
Car: 1984 camaro z28
Engine: 305 v8 h.o.
Re: stock 305 after market parts
not bad parts, could save up some more and drop a 350 putting out 300+ horse but if thats what you want go for it. be sure to get the y pipe in the accessories of the headers, otherwise you will have problems.
Car: 1984 Trans-Am
Car: 1982 Z28
Engine: three 350s, all casting #370010
I don't think that cam will work with a stock carb. The duration is too long, it will throw off the carb. Look at a good cam for the stock carb on this furom there are a bunch of threads about it. Also the rpm range is 1600-5800 which is good for a race car, but hurts the take off speed. You want to get a cam with a duration of idle to about 5500.
Car: 1982 Z28
Oh and don't let people on here scare you away from building your 305. They are good strong motors. I am actually consider trading one of my 350s for a LG4 305. I like having correct motors and such. haha
Car: 1984 Trans-Am
Car: 1984 Trans-Am
Haha ya i figured if i got a good 305 why not use it. If i ever blow it then im hoping the parts get will swap over to a 350
Car: 1982 Z28
Yeah I believe all their parts are interchangeable besides the pistons and maybe the rods. As far as cam gos I don't think it matters if you are changing the carb but I would still stay with one in the rpm range of idle to about 5500rpm.
Car: 1984 Trans-Am
http://www.jegs.com/i/Edelbrock/350/7516/10002/-1
do you think this intake would be any better than the jegs one. Thank you
Car: 1984 Trans-Am
Thank you for the input. This is why i come here everyone seems like they know what they are talking about
Car: 1982 Z28
No the rpm range is 1500 to 6500rpm, again good for a race car that goes in circles but hurts low end torque which you want for take off speed. Also it won't fit under a stock hood. A performer intake would probably be better.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
That manifold range is fine stick with a performer RPM or an air gap stay away from a regular performer you will be much happier.
The regular performer is not much better than stock
Car: 1982 Z28
Those won't fit under stock hoods will they? Plus doesn't that RPM range hurt low end torque?
It might hurt low end a little but with any decent cam I would rather get the RPM. Totally up to you just my experience with the 2.
Also if you end up going 350 you are really gonna want the RPM.
I have a Performer RPM. I have plenty of low end torque. Car will even highway cruise at 1200 RPMs without complaining (T56 double overdrive!). I also run a stock hood. Clearance is tight, but I'd rather give up filter size than give up power band. For a stock car the stock intake is plenty. The intake is one of the things I would change after doing exhaust. But if you're doing a cam swap to an xe268, that cam will probably pull to 6500+ RPMs in a 305 assuming the rest of the engine can handle it. A regular Performer intake will choke it badly.
Car: 1984 Trans-Am
Car: 1982 Z28
Also a 305 can't really handle RPMs above 6000 because they are 2 bolt mains. They red line at about 5500 so having idle to 5500 parts is a lot more logical than 1500 to 6500. Parts that are in the 1500 to 6500RPM and up range are made for 4 bolt mains. If you push an engine to RPMs its not made for it can completely tear apart your engine. Meaning it would impossible to rebuild because the block itself would be busted up. If you don't know what a 2 bolt and 4 bolt mains it is referring to how many bolts hold the caps that hold on the crankshaft. If you push an engine to RPMs it can't handle it can rip out the bolts and you can imagine how much damage a crankshaft coming loose could do. It would ruin every part of the engine.
The 305 can and often does spin to 6k. The l69 spins to 6k and enjoys it. Any decent aftermarket build for a 305 should spin to about the same. Getting whatever you want but I cannot reccomend the regular performer for any decent cam.
I could be way off base, but stock 305 heads have combustion chambers around 58cc's, yes? Those Vortec heads have 64cc chambers. I would think that this would lower the compression ratio enough to hurt performance.
I really, really disagree. Having some nice aftermarket rod bolts is far more important than the number of bolts in the mains on the engine block. I wouldnt spin a two bolt past 6500, but I've seen then hit 6500 regularly with ease and never seen one come apart because the main caps failed. ARP rod bolts make a big difference high RPM longevity.
Personally if I were you I would get the same heads bare have them milled to 58cc else you will loose about .6-.7 compression. Then have them set up for larger lift and studs. Have a shop do all the work and assemble them.
Just my thoughts on it.
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
That cam in a 305 will blow by 6000rpm easy.
It does 6000rpm in a 400 sbc.
I would use it but I like DRIVING my cars. Each person has their own street driving level of difficulty. If you have a stick then use it if you have an auto you'll need a converter to get into the power band.
Vortec heads and performer rpm intake are a great combo and would match the cam well too. Have the heads milled to take advantage of the cam and vortec heads to 9.5cr, you could also use a thinner head gasket to aid in cr. 1.94 intake valves a fine. I seen guys running 12second in the 1/4 mile thinking they had 2.02 to find out later they had 1.94's
when doing this type of upgrades make sure the motor is worth the investment regardless what it is. what are the miles on the motor, does it leak oil, is the cylinder pressure good and even across the board? ect, ect,..
Then work on the cooling system as the stock one may not be good enough to support the extra 100hp of cooling needed in the heat of the day.
Then see if the rearend is hearty enough to live behind it all. which brings up your rearend gear ratio? Higher gears will make this cam a better choice.
when your done most will have a hard time when you tell them it's a 305.
I'm rebuilding a 305 currently for my daughter, but will replace the LG4 with the newer 305 roller cam block for many many reasons... current oils, cheap hp, mpg, build one motor taking my time getting parts then replace old one in a day, ect,ect,...
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Ewwww flat tappet cam, but it's numbers do look good though.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Engine: gone
Transmission: gone
Axle/Gears: gone
but build a 350 and have more hp...soo...anyway sounds like a fun build have fun. I have nothing useful to share.
Having bought my 87 Formula with the LG4 305 back in 86, I began bumping the power with mostly simple add-ons:a set of 1.6 rockers which were a direct replacement, a 1/2 inch carb spacer, K&N air filter, a Gale Banks 3 inch exhaust system, a 3 inch diameter cat/con, a HyperTech chip, a Q-Jet electronic carb tune, one step leaner spark plugs to go with the tune up, a B&M shift kit(probably the hardest to do), a 185 degree thermostat, and other things I have probably forgotten. 220,000 hard miles later, still barks 'em off at the 1-2 shift. As I am now restoring and upgrading the car, I will definitely go for more cubic inches, but the stock motor has never had the heads or oil pan off since new. I am guessing all of these additions were a $1000 over the first ten years I owned the car, with the exhaust system being the most at around $500, still using the stock manifolds. The one time I had it at the strip, it ran 15.06 with the 2.73 rearend. Highway cruising buries the 85 mph tach and runs out of steam at about 5500 rpm, so I am not sure how fast it has gone. My two cents worth on the 305...
Car: 1992 RS vert
Engine: forged 383
Transmission: a busted one for now ;)
Axle/Gears: 4th gen 3.73
dont waste money on a box cam. get a custom cam and some aluminum heads, headers to a straight pipe, open element with a K&N. consider a cheap junkyard turbo (: i drive a 305 and my friend with a 350 and a 455 always rip on me so ik whats up
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
The 305 is practically a guaranteed loser vs the 350, 400 and 455. But just because it can't make power like its bigger brother the 350 doesn't mean its crap either. I plan to get a '89-'93 chevy 1500 pickup and they have a 305 tbi and have thought about swapping in a used 350 but I can always beef up the 305 to make an acceptable 280 hp and 310 torque
Engine: 5.7 TPI
It's not gonna be a Race truck just my work / Daily cruiser Truck to Enjoy, gonna paint it dark teal metallic to match my Maro and for A Race truck to take to the track I'll get a 454 SS truck !
