Atomic EFI
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
1 Post
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: Atomic EFI
4300 dollars?its cheaper to swap in an ls1 with aftermarket harness.i wish someone offered a control for a gm tbi like that with a wide ratio oxygen senser that would automaticly adjust for bigger cams or heads.
Re: Atomic EFI
You mean like the one Holley has had on the market for two years?
Car: 1992 Z28
Engine: 388
Transmission: 4L70E
Re: Atomic EFI
Atomic does control timing and has some very cool innovations to it as well. I got a chance to go over it this week and the way they do the fuel rail in the throttle body is very good, the ecu is integrated to the side of the throttle body, incorporating the TPS in the circuit board too. It's also available as a returnless system so you don't have to run a fuel return line back to your tank. All in all it's a very interesting design. I'm a port injection guy myself but if I were doing a simple upgrade for my kids project I would have to look at this unit along with FAST's EZ EFI and Holley's Avenger too. It's an interesting time in the EFI business.
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
Re: Atomic EFI
The Atomic EFI uses a pulse module for the fuel pump which is why it doesn't need a return line.
I'm sure the ignition controls are pretty good since it was made by MSD.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Atomic EFI
It also has idle spark control to help control the engine speed. GM has used this feature since the 80's, so its not necessarily a new idea, but it does work.
The one thing thats a problem is that it is a wetflow system. This means that you have all the nuisances of a carb in cold weather. Things like poor fuel distribution, and hard to tame acceleration enrichment. Also means that the system absolutely depends on the WB O2 for good operation since its speed density. Wetflow systems and speed density dont always play nice since the fuel can drastically change the temperature of the incoming air charge.
Re: Atomic EFI
From what I saw, the timing is handled by a software logic model that essentially emulates a spring and weights distributor, with some minor retard built in for high temps. Seems like you can set the idle cruise, and total at WOT, but no spark maps.
Temp changes obviously effect performance/tuning as well. That's why there are really very few true VE based systems. FAST, Holley, Motec, and a bunch of others are really all pulse width based. They don't have that extra cal that correctly figures true VE.
