Air compressor? help
i dont know if im in the right place to post this but i want to get an air compressor for my house and was looking into a 60 pound one single stage i believe for about 750. is that a good deal or whats the best one to get?
i will be doing some painting and a tools.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Air compressor? help
get the largest brand name that your wallet can afford . you will be glad later down the road . once you have one you will wonder how you ever got by with out it before . so very many uses , good luck .
1 Post
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
i have a craftsman pro series 75 gal and it does what i need and its a quiet motor vs the standard 75 gal red compressor from them.
i agree with the others, if you can get something bigger, do so. by getting a bigger unit will mean less cycling. when i run my impact or blow dust out of the garage it dosent take long before it starts to cycle.
for what i do is fine.
Most body tools take a ton of cfm.It's not pressure that matters so much as the cfm del'ery.That means a two stage pump and normally a 220 service to run it.Trust me that yrs ago I went threw the stages of upgrades buying and sell compressors until I got to a point of one that would do everything I wanted to do.In the end it cost me alot more than if I had bought what I needed in the first place.Knowing what to look for is of course important.The pic I am posting is a I/R cast iron 60 gallon that I/R doesn't build anymore unless you up into the $1.500 to $2,000 range and parts are still available.Given the amount of use I do,it will be past on to my grandkids as long as I take care of it.I shopped Craigslist and ended up getting it for $100.00 and then added a new motor for $250.00.Still a very good buy.
I got a new air filter housing and oil filler plug to it and this is a pic of it before those parts came in:
Memory serves me correctly it is 15cfm@ 90 psi.From 0 to 125 psi is timed at about 4 minutes because I reset the pressure switch.
Location: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
Best advice . Mine's a Craftsman. Use it for the cars, boats, you can pretty much name it. Never regretted it.
Billy Decker
09-04-2015 03:46 PM
