classic industries power antenna mast
Car: 88 trans am gta
Engine: 305tpi
Axle/Gears: 9 bolt 3:27
Has anyone had any experience with classic industries power antenna mast g4825 seen on page 114 in their book? The cable in my mast broke and I am trying to find a replacement that looks like the stock one.
Thanks,
Brian
Thanks,
Brian
Re: classic industries power antenna mast
You can just change the cable. Do a search. The part is cheap, and you retain your original antenna. It is not all that hard to put in.
Here is a good thread with part numbers:
https://www.thirdgen.org/forums/hist...ld-thread.html
Car: 1987 Camaro IROC-Z
Engine: LB9
Not really anymore, read that thread more. the GM kits to fix it are discontinued.
Former Sponsor
We have original GM masts available on our site. Here's a link if you're interested. Thanks!!!
http://thirdgenranch.com/-strse-984/...nna/Detail.bok
Engine: 305tpi
82tarecaro- Thank you, that's a big help.
Thirdgen ranch- I see that the mast you sell is new GM but are they exactly like the original or did GM make any alterations to the part over the years.
Thanks again for the help,
Brian
Brian
Car: 87' IROC
I have that mast from Classic Industries. Works great with my original antenna motor and all the stocking mounting provisions. I've had it about 3 years now.
Engine: 305tpi
87350iroc, How did it look compaired to the original? Were you able to use the original bezel? Is it basically the same length as the original?
Thanks again,
Brian
Thanks again,
Brian
Car: 87' IROC
It looks identical to me. I'll see if I can dig up some pics. I re-used my stock fender hardware with no issues. Looks perfect. Length was good.
Engine: 305tpi
Thank you for everyone's help. looks like I will be ordering a mast assembly in the next few days.
-Brian
-Brian
snowflake
10-19-2015 10:24 PM
sailtexas186548
08-24-2015 10:11 PM
