Schumacher Battery Charger
My Bride got me a Schumacher battery chargera couple yrs ago when the battery would mysteriously die. Last spring, I only had to charge the bat after winter storage. This summer I have started the carto pull it out the garage to wash it. Went on vacation, battery was dead!
Put it on the charger, & the needle stays around the red zone, not taking much charge. The unit gets pretty warm to the touch. I've never realy paid attention til I sawthe needle not moving a whole bunch even after 8-10 hrs on charge.
I put it on Maint Free battery, 2 amp.
The Pos terminal was also noticeably warm to touch, the Neg was ok.
Battery is 3 yrs old, AutoZone hi-end.
Is Schumacher a good to decent brand??
I'll jump it later tonight & go for a ride.
If any one has ideas, tips, or tricks, I would appreciate the words of wisdom!!
Thanks!!!!
Thanks!!!!
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Schumacher Battery Charger
Get a floating battery charger, $7-$9 from harborfreight.com
I got 3 of them now, and they work better then my pricy big box charger and has brought many back from the dead.
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
I've had a Shumacher for years and it has always been great. I do use a battery tender to keep everything ready and charged up.
Engine: gone
Transmission: gone
Axle/Gears: gone
schumacher is good stuff. autozone batteries not so much. Interstate
![nod](https://www.thirdgen.org/forums/images/smilies/nod.gif)
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Those floaters are tiny but powerful, works different and works right.
Brought back several from the dead that the big box could not.
Well....
....![Frown](https://www.thirdgen.org/forums/images/smilies/frown.gif)
No time for a ride!!Tomorrow I'll go under & see it any wires are loose, fried, etc b4 we try a jump.
Gumby, thanks for the tip about a floater.
(edit)
Undercover--
DOH!!! A friend of ours owns a auto repair & sells Interstate!!! DOH!!! ( Burry head in shame & disgust for getting AutoZone )!!! Let the thrashing begin LOL!!!
![go crazy](https://www.thirdgen.org/forums/images/smilies/go crazy.gif)
(edit)
Undercover--
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
I have 2 Schumacher maintainers(1 for 5 years) never had a problem with either.
Just so you know Interstate batteries are made by Johnson Control. Johnson Control also makes Autozones batteries. Most Duralast batteries have about the same power as an Interstate, some times more. A Duralast Gold(hi end) is better than an Interstate.
Car: 83Z28 HO
Transmission: G Force 5 speed
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
It's definitely not the charger, grab an optima and you're golden.
