Summit Thermostat gasket!!!
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
Just got a summit thermo gasket to replace my leaking paper gasket. Summit part number SUM-G2399. Gasket is awesome very heavy duty. It sealed very nicely no leaks and looks as though it should hold up for a long time. It appears to be the same gasket as this Mr. Gasket one http://www.summitracing.com/parts/MRG-738G/ and it is half the price.
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: Summit Thermostat gasket!!!
AZ sells the same gasdket for 6.59...
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I got one from a local auto store and it was around $18... But I can vouch that when I replaced my crappy leaky paper one with this one, I never had a leak after that. This is one that I would definitely buy again.
Engine: gone
Transmission: gone
Axle/Gears: gone
Never have seen one like that. I usually do just fine with the paper ones..Will keep in mind in case I get a problem with one.
school boy
10-22-2015 11:47 AM
