Hotchkis Vs. Spohn Subframe Connectors
Car: '89 Firebird
Engine: V8 305 5.0 L L03 T.B.I.
Transmission: 700-R4
Axle/Gears: Came with the V8 (ID coming soon)
I Like Spohn's Torque Arm and so had a look at their Subframe connectors. However I have generally read that Spohn's connectors don't create as rigid a frame as Hotchkis. The Spohn Connectors seem to connect to more points on the frame but I'm not sure that means much. Does anyone have any thoughts?
Car: 1987 Black IROC-Z (SOLD)
Re: Hotchkis Vs. Spohn Subframe Connectors
I have had the Spohn tube type SFC's since the design was changed from the square boxed ones. The tube type sets up high and are not visible. My car with them is better now then it was new...original owner. Good quality buy.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
spohns are better. period
you are supposed to stitch weld the spohn ones to the pinch rail too, and that creates a very tight chassis.
Car: 1986 IROC-Z28
yep, that's how mine are done, i love it. still some dash creaking over very large bumps and pulling into my very steep driveway at an angle....still 90% improvement
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
If your griding on the bars over a bump, then your lower shock mount is gonna dig into it like a snow plow too. Lots of stuff that hangs lower then them.
If they are the lowest point under your car, something is off.....
Hello,
We offer a very nice set as well so I figured I would give you another option.
Our SFC's can be seen here- www.umiperformance.com/2400
Our SFC's bolt and weld into the rear control arm and weld in the front as well as the center subframe. If you do a search you will find some great results and feedback on our SFC's
Good luck with your decision and if I can help I will be glad too,
Ryan
Ryan
Car: 89 formula 350 & 2001 ws6 ta
Engine: 350 tpi & ls1
Transmission: 700r4, t56
Axle/Gears: 9 bolt ? & 10 bolt 3:42
BMR
UMI
SPOHN
all make boxed sfc's
UMI
SPOHN
Car: 1986 Iroc Z
Engine: 350 tpi
checked prices between umi and spohn. both are $199.00 but spohn charges an extra $45.00 for red or black finish. umi does not. also looked at bmr. bmr is $199.00 also. no charge for finish. hotchkis's are $271.95. ground shipping is $38.-$47. just something to look at as i am pricing them myself.
Also not all will fit stock exhaust or dual cat
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
My suspension is ALL UMI...sfc, lcarb, lca's (round), panhard rod (on car), wonderbar, poly bushings, etc..
Guest
Posts: n/a
There are a lot more important reasons for the choice than round or square/rectangular. The only benefit of round in this particular use is round tubing does not care how/where the force is being applied to it, its going to react exactly the same. The stronger pieces are, quite simply, going to have more area of steel. Given the space restrictions where these are mounted... something other than round will have more steel in the same given space.
In the interest of hoping this doesnt degrade yet again into another pointless argument if you disagree... please search first.
just ordered umi sub frame connectors and rear lower control arms. i will post review after they are done. cant wait to get rid of the shake rattle and roll out of my t top iroc
ok just took a ride in my 86 cammy.my local body shop did the work for me.(i dont have a wielder or a good lift.)they installed my umi sfc and new lower control arms.i would say 90% of the rattles are gone. the car feels 100 times better when going over a series of bumps in a row(crappy long island roads).frame flex is gone.in the past if i hit a series of bumps at high speed the rear end would step out slightly which i would have to counter steer into.no more!!!!! now on to the rear control arms.in the past with a non posi rear if i mashed the gas on a tight turn the rear tire on the inside of the turn would lose traction and the smoke show began.....no more. mashed it and she bites hard! the whole car feels alot more stable.i cant compare them to any other brand so i dont know if they are the best or if there are better out there. i can say i love the difference in my cammy. hope this helps someone.
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
I use both round tube and square tube.
Car: 87 formula
Transmission: 700
Axle/Gears: 12 bolt strange 3.73
my entire car is spohn. the only thing h haven't done yet is the k frame and a-arms. i want to do then but just don't have the money. they make a great product. i never had a problem with them and other guys in my club are using spohn and love there stuff.
the only thing they don't make is a strut tower brace.(sucks)
1 Post
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
No... the shock mounts are between the rear wheels, so they generally won't hit any bumps.
that being said, if you bottom out on the alston/,mac SFC under driving conditions, excluding speedbumps, you are doing something wrong. for that matter, they should not hit speedbumps unless the k-members hits them too.
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
I have the square style Spohn on mine, I absolutely love them. They fit tight to the body and make a GREAT jacking point to lift the car. They have gotten a little crusty over the years though.
Car: 1991 Chevrolet Camaro Z28 C/V
Axle/Gears: 3:23 posi
Has anyone tried the subframe connectors from Top Down Solutions? I have heard really good things about them and the way to they mount up. They are a weld in style. I know a couple local guys that ordered them and love them.
http://www.top-downsolutions.com/pro...s_id=90&page=2
Car: 83Z28 HO
Transmission: G Force 5 speed
I can tell you the square style I have on my car are for sure heavier than most any tube type, but they do make a great point to jack the car up...lol
I felt a difference as soon as I put them on. My T-Tops used to creak when I hit bumps and made a popping noise when I went up my driveway across the sidewalk. No creaks or pops anymore!
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
Spohn subframes are great but I had a bad customer service experience with them. So do your research before you buy cuz once they have your money, you will need a crowbar to get it back out of their hands.
I have MAC frame connectors which are essentially the same as TDS ones. They hang down a bit low though, but they do the job well. Amazing difference. I opted to put on a second set of perimeter style SFC's (SPOHN's) and now I have full braced the underbody frame.
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
https://www.secureway1.com/alston/in...?productID=196
That's not entirely true... There are the debates about 'square vs. tubular' style, as well as 'perimeter vs. inner frame rail'. These will provide different types of chassis re-inforcement, but they probably won't be noticed by the average daily driver. There is bracing that will reduce flex fore and aft (drag), and then there's lateral chassis bracing (road racing and handling). All connectors work 'good' and are better than without, that's for certain, but to say they are all the 'same' in functionality and strength simply isn't true.
1 Post
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
I have Hotchkis on my Car right now, and would NEVER buy them again...They are the hardest to weld of any connectors I have ever seen.The fit was really bad...On top of it all I had to cut, and shorten my EdelBrock Crossover in order for them to fit...Poor planning on my part, but Still.....
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I have the spohn ones. They work well, but you need to weld them to the pinch welds rather than the floor pan to get them to work properly. This ties the floor pan, front, and rear subframes together. Not easy, but the results where good. The car is no longer a soggy wet noodle over bumps and around turns.
darwinprice
17
10-11-2015 11:51 PM
TMZIrocZ350
10-07-2015 12:09 PM
tmork454
09-29-2015 06:33 PM
