Hypertech and Jet chips?
Do the hypertech and Jet chips really work or is it just
? deos anyone have any of these in there car? If they work wich one is better for an increse in Hp
![bs](https://www.thirdgen.org/forums/images/smilies/bs.gif)
![Confused](https://www.thirdgen.org/forums/images/smilies/confused.gif)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1987 Black IROC-Z (SOLD)
Re: Hypertech and Jet chips?
They work, just NOT well enough to be worth the money they cost. You DO NOT make big gains in horsepower using a Prom (chip) in the ECM on stock engine.
I was told that there is a member named Kevin Lorenzen, who's Dad goes by Dyno Don. I'm trying to reach them to burn a Chip for my 89. If you locate them, shoot me an e-mail
I had a Hyper Tech Chip before when I had an 89 Vette motor in it. Now it has a lower compression motor and an accell intake. My stock prom no longer works well.
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
If you go read on the DIY prom boards they talk all about those chips. None of it is good. They add a little timing advance and tell your fans to come on sooner. Thats about it. Do not waste your money.
Engine: gone
Transmission: gone
Axle/Gears: gone
your better off having brian at tbichips.com burn you one then buying those. the best option is a DIY yourself tuning like dynamicefi.com
KO1
16
10-15-2015 05:00 PM
