BMR adjustable rear control arms
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Just recieved my BMR on-car adjustable rear control arms. I ordered them in black hammertone with the poly bushing on the body side and the heim joint on the axle side. Just as expected, the quality is top notch. Coating looks great, and the poly bushings were already installed in the arms, so no need to screw around with those. I was surprised at how light they were too! I believe they are made from chromoly tube, and they feel a lot lighter than my old granatelli standard steel tubular arms.
Unfortunately they won't be on the running car for some time since it's in restoration mode right now, but I'm sure they function as good as they look. I've used BMR before and they never dissapoint. Thanks BMR!
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
1986, adjustable, adjustible, arm, arms, bmr, bolt, cam, control, gen, instructions, lower, rear, thirdgen, trans
