need plug wires
Car: 1991 Z-28
Transmission: TH700
need plug wires
I just installed some edelbrock headers and the heat has cooked the plug wires so bad that the engine keeps missing. what kind of wires will take the punishment?
Jacobs has a set of wires that will take 1600 degrees. It will take the punishment.
The other way to go is to get a custom set of wires with all 90* boots (brand is up to you, i have the holley annihilator 9mms and love them) and use a wire loom to organize the wires away from the headers.
However, with the price of custom wires ($60-$100) and the wire loom (around $40) ...you could get the Jacobs.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Custom cold air intake w/K&N, SLP airfoil, ported & polished plenum, TB coolant bypass,Crane AFPR (47psi),94 octane,Crane Extruded Alum. 1.6 full roller rockers, Timing set from 4*BTDC to 10*BTDC,MSD coil,MSD6AL, Holley 9mm Annihilator Laser shot 50 wires, Ac Delco cap,rotor and plugs, Bosch O2sensor, SLP 1 5/8 headers,SLP catback,3:73s,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Street legal with stock throttle body, runners,intake manifold,cam, and heads. Coming next..9# Procharger!
91 Formula
305 TPI 5speed
1LE/G92/WS6
Try the 8.5mm MSD wires with 90 deg boots. MSD wires are suposto be the least resistant on the market (40 ohms), get them from summit. not to expensive. crimping them takes time but not to hard and yo uget to rout them how you want them. wirelooms will also help (i have the wires, havenot put them on yet because its to damn cold.
-Stell
1988 IROC 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans , K & N, 160 Thermostat+ Temp Switch, Relocated MAT, Cold Air
-Stell
eightsixseven
08-14-2015 03:09 PM
