Which Anti-Freeze is best?
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
what are you guys running in your cars and which is the best?
Car: Red 1988 Iroc-Z hard top
Engine: 305 ( LSX swap soon )
Transmission: 700r4 ( T-56 swap soon )
Axle/Gears: What ever gear that come in 88 iroc
Re: Which Anti-Freeze is best?
zerex green stuff from napa.
Engine: L31 350
so is k-mart, they have their Peak anti freeze on sale for $9
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Don't be dissin K-Mart! It's a midwest thang..
But I buy the green peak stuff. Seems to work good and I like the color
Car: 88Roc Flame Red Black/Gold Pkg
stay away from dexcool. go with green stuff.
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
dexcool As well glycol based antifreeze eats aluminum....
I use iceclear it's about the same price and it polypropylene based
http://www.orisonmarketing.com/deice...ntifreeze.html
Engine: 231 / 383
Ohh.. they will I promise you that..
PS dex cool is nasty it forms into a corrosive white powder
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
I've been using Zerex. It seems pretty decent...
Car: 91 Trans Am
Engine: LSA
Transmission: T56 AWD
Axle/Gears: 8.8 4.10
Engine: L31 350
whats this royal purple stuff everyones talking about??
Car: 1990 RS Camaro
Engine: 305 TBI
Transmission: T-5 stick
I use the peak extended life stuff with a little water added. There is no better corrosion protector then coolant. BUT, nothing cools better then water. Get a combination of both and you'll be good to go.
Get the cheapest green stuff. Water is the best coolant btw, I run straight water in all my cars spring-fall, then drain a little and add antifreeze until the tester says it's safe (-20* here in wisconsin) for winter.
otherwise, winter i run 50/50 of watevers on sale, and it gets cold in JERSEY! i like to be around -25/-30 for the winter. in the spring like today actually lol, i drained the radiator about 1.25gallons and threw in tap water with water wetter. u never want to run straight tap water or just straight tap water with water wetter. personally the best thing to run is 15-25% antifreeze and tap water with water wetter. water wetter does have some anti corrosion properties but they dnt recomend it with just straight tap water.
if u got some money to blow u could use straight distilled water and water wetter for the max cooling and it being cheaper than the premade ICE stuff.
Car: Blue 84 z28/Cyber 2010ss/rs
Engine: Dart headed, 12:1 355- 510/530 cam
Transmission: TKO 600 Lakewood Bell
Axle/Gears: Richmond 410 Spooled
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
