Suspension Upgrades
Car: '85 Iroc-Z, '03 Z71
Engine: Blown 383, 323 SBC
Transmission: 700r4, 4L60E
Axle/Gears: GU6 3.42, G80 3.73
Suspension Upgrades
Just got some quick questions for you guys and gals.
Im in the process of rebuilding my 85 Iroc and im know for sure i want to get a aftermarket panhard rod, lower trailing arms, subframe connectors, and a torque arm for my car. I just need some basic information on the parts im considering. Im looking for guidance and direction of what to do as this is my first ever restoration and im a noobie at this game.
Im looking at a suspension package from Hotchkis. Ive never heard anything about the company, just seeing if anybody has used anything from them.
http://www.summitracing.com/parts/HSS-1801/
Here is a torque arm im considering.
http://www.jegs.com/i/Jegster/550/40...oductId=744013
And as far as subframe connectors, im at a loss. Should i go with bolt on, or weld in. I prefer bolt on if possible... Im not the best welder.. LOL
But thanks for any advice/input!!
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
Re: Suspension Upgrades
I've added mostly UMI suspension parts and I like them because they're good products and the price is decent. As far as SFC's......I'd go UMI weld in. Spend the xtra bucks and have someone who knows what they're doing WELD them in. You'll appreciate the difference. Remember, these beasts are 20+ years old and the suspension parts should be replaced before any power add ons in my opinion....what's the point of adding power if ya can't steer or stop the thing safely? I know it's a slow approach, but it's well worth it in the long run. BTW....UMI usually runs promotions and I'd wait for one. Good luck
Looks like a nice product. Im going for cheap and yet effectiveness for these upgrades. And as far as stoping power goes... only time ive ever used the brakes in the car was when my dad was towing me to my new shop from my uncles chicken coupe... lol. All 4 tires locked up when i stood on them.
As far as front suspension goes, how critical is upgraded front equipment?? Its going to be a mostly street car. Im shooting for 550hp with this car...
Any other suggestions from anybody else? Don't be shy..
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
you can get that same package through umi for abit cheaper. Also depending on the mileage of the car I would look into a front end rebuild kit. Are you lowering the car? or keeping it stock ride height
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
umiperformance.com
http://www.spohn.net/
http://www.bmrfabrication.com/
any of these companies sell reputable parts just about everyone on this site probably has a part from one of them. Not saying everyone.
Car: '86 T/A
Engine: Vortec 406sbc-carbed
Transmission: 700r4-vette servo/B&M shift kit.
Axle/Gears: Ready to splode
When I installed my Spohn adj. steering brace(aka wonder bar) I noticed a huge difference in the car. Just rolling the car off the ramps I noticed a huge reduction in flex in my t top car. I also recommend polyurethane bushings everywhere. I have the WS6 sway bars with poly links and bushings and it handles pretty tight.
Car: '86 T/A
O yea...Forgot about that ;P
Hello
Thanks everyone for suggesting UMI Performance. And when you go with UMI Performance you are getting excellent customer service and tech support. All of the products that we manufacture are made and tested here at our own facility right here in the USA. If you have any other questions feel free to ask. And I will be more than glad to help.
Brad
Brad
Car: 1986 Trans Am
Engine: LG4 305 carb
Transmission: auto 700R4
Axle/Gears: 2.73 open
jb3829:
How do you like the KYB gas-adjusts and the GR-2 struts? I have those exact parts brand new and sitting around waiting to go in. I was planning to do everything at once.
~Matt
~Matt
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I'm going with Spohn, mainly because they offer the most products for us, so far, that and they do all tubular with their new Del-Sphere, that is also adjustable, I am big on tubular and want as much adjustability as possible on my car. Also i have been hinted of new products coming out from them. I heard this last year and haven't seen any new products added yet, but I know their coming, but what could they be.
But UMI has added a few products since I last looked, like sway bars and cast/camber plates.
I'd say though, figure out everything you want, then figure out which company would best suit your needs now and in the future.
Right now my car is ready for my body man, so maybe i should just buy a new front end kit? I cant see the sense in finishing up the car, put the motor/trans in it then decide i want to upgrade the front and have to stand on my head to get at bolts....
Car: 1986 Trans Am
Yea I would heave them check chassis parts like the k-member before the motor goes back in. Do a front-end rebuild now before the motor is back in.
I have read on here that as far as lower control arms go, boxed would be more for drag racing. It would hinder your maneuverability but support traction in a straight line.
~Matt
~Matt
Originally Posted by 86TA4SALE;4501085 check chassis parts like the [SIZE=4
k-member[/size] before the motor goes back in
~Matt
~Matt
Is it this - http://www.byunspeed.com/images/SPO704.jpg
Car: 89' IROC-Z
Engine: LO3
Edit: Yes that's a k-member, its what the engine sits on, big hunk of metal under the motor, most likely rusted to hell, but don't get this wrong, it is a very strong piece.
What your saying is what I plan to do. I want to totally redo my whole suspension so the car can use all the power or what little power it has to its full potential, before I think about doing things like a motor swap or HCI.
Boxed vs Tubular is like Black vs White. Its going to get a 50/50 rap either way. Do what makes you happy, and for me, that's tubular. Have fun.
I see UMI has their Roto Joint up on their page now. UMI you really are trying to bring me in aren't you. A couple more products and I think it could be possible. I have about another year before I get into suspension so you got time
Last edited by I H8 WWD; 04-07-2010 at 01:24 PM. Reason: Added answer to above question.
I really appreciate the feedback im getting. If anybody else wants to add in, feel free. Im open to all suggestions. Thanks again!!
Car: '89 Formula
Engine: 305 TBI
On the subject of steering, any advice on new steering boxes? I am pretty sure mine is worn out, and I figure getting one off another 3rd gen will just replace the same issue.
Car: 1986 Trans Am
There are different ratio steering boxes, so don't just pull one at a yard and think it will bolt in. Check the link below under the "steering" section. It gives good tips and advice for fixing your steering box without just replacing the whole unit.
~Matt
~Matt
Car: Red 1988 Iroc-Z hard top
Engine: 305 ( LSX swap soon )
Transmission: 700r4 ( T-56 swap soon )
Axle/Gears: What ever gear that come in 88 iroc
is that true that using polyurethane bushings is bad ? because its made out off hard rubber ?
Car: '86 T/A
I see no downside of using poly bushings. They're low cost and you notice a pretty big diff in performance. So far, I only have poly swaybar endlinks and bushings and engine/transmission mounts. I love the improvement in handling and the poly engine/trans mounts help you put more of the power you're making to the wheels. From what I read, the only 'bad' place to put them is in the lower control arms(in the rear). In a corner, they could bind up since they don't flex as much. Straight line is supposed to be better tho. But I think UMI and Spohn make setups that cure this issue.
where can I buy none polyurethane bushings LCA ? I have a link back when I own a 4 gen on ls1 tech, but its been a long time I lost it. any one know ?
Car: 1986 Trans Am
Sorry I forgot the link for the steering box:
https://www.thirdgen.org/forums/susp...nsion-how.html
This is actually a really good thread (^)and I have to keep looking for it.... bookmarked.
Some people have complained about the poly parts squeaking, but you would hear it more from outside the car. Below is a link to Spohn's poly bushings and mounts.
http://www.spohn.net/shop/1982-1992-...s-Accessories/
~Matt
~Matt
Car: 1983 camaro
Engine: 350 soon to be 355
i would start figuring out what you all want and buy it from summit. Same price but shipping will only be $7. even if they are a lil more the shipping usually more then makes up for it. Yes and also if it doesnt have to be right now wait for UMI to have its sale, i bought all my stuff when they had it on sale and saved a couple hundred.
Well i appreciate everybodys feedback. I think im going to go with UMI Performance, and I think im going to wait for a bit and see what goes on sale. Ive called and talked to them, Brad to be exact and they seem to be very professional and every question i asked, he had and answer for me. They reeled me in...
84 TA NV
09-06-2015 08:02 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
19821992, 2005, body, fbody, gen, generation, iroc, motor, profamence, supension, suspension, trailblazer, trans, upgrade, upgrades
