Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
oil filters! which is best!
Old 05-21-2010, 01:30 AM
  #201
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: oil filters! which is best!
Originally Posted by Jim85IROC
Update:
I snapped a pic of the old and new PF 1218 filters for your enjoyment.
New one is on the left, though I suspect that's fairly obvious from the pic.
My observations:
New one is shorter, has thinner metal, and a much thinner gasket. I still haven't pulled one apart to see how bad the inside looks, but if the outside is any indication, I'd place this filter firmly in the "garbage" category.
The one on the left is definitely an E-Core design. Look down the hole of the one on the right. I'll bet it is the old design with the metal center tube.
Old 05-21-2010, 02:35 AM
  #202
sparkplug619's Avatar
Car: 1990 RS Camaro
Engine: 305 TBI
Transmission: T-5 stick
Originally Posted by 3rdgenmaro
How much does it cost to rebuild a motor?
Oh man, I need to spend $200+ on a filter because im going to have to rebuild my engine if I use another purolator. Get real
Theres millions of cars running around with over 250,000 miles that probably ran with fram the whole life of the vehicle that can probably still go another 50,000+ miles with fram filters.
Unless im going to use my car for more then daily driving/ weekend dragging, I'll never pay that much for something that is recommended to be replaced every 3,000 miles.
Old 05-21-2010, 03:05 PM
  #203
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
True that. Besides, unless you've blocked the bypass, most of the oil goes unfiltered anyway.
Old 05-21-2010, 07:59 PM
  #204
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
The ecore catches a bad rap for no particular reason other than it's design characteristics, while they may not be very aesthetically pleasing internally, they are still quite functional. They filter well and they are not any more failure prone than a non ecore design.
I cut open every oil filter i use and have never had a failed ecore filter.
Old 05-22-2010, 05:19 PM
  #205
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I use the Fram HP4
Old 05-22-2010, 10:32 PM
  #206
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
I use Amsoil here.
Old 06-01-2010, 07:54 PM
  #207
BOOT77's Avatar
Just bought one of the canton ones to try out. http://www.summitracing.com/parts/CTR-25-242/ Glad to see I picked the right size as some1 else has gotten one a few pages back, too bad I didn't see this post before that.
Used an oil pump primer for the 1st time too check my block for a possible flow problem when my cam went out, seemed to get good flow. Reason I was checking is because my oil pressure was good but when we pulled the vlave cover oil was only dribbling out while at 3000rpm. Had to be the clogged filter from the lobe dieing, cause it was full of shavings when you poured it out.
Anyways with no oil the primer turned like crazy, with oil/filter it bogged my drill right down. Now yah the oil was cold, but still led me to research out a higher flo-filter. I can't imagine it's much, but to me I'll take any small improvement.
Old 06-10-2010, 01:36 AM
  #208
CamaroIROC88350's Avatar
I'm going to have a AC Delco Duragard oil filter put on during my next oil change. I paid more money for it but I like AC Delco and their quality.
GeneralIesrussi
Carburetors
06-20-2024 07:21 PM
Hotrodboba400
12-10-2019 07:07 PM
gta892000
08-11-2019 11:16 AM
89 formula TPI
09-07-2015 11:06 AM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: oil filters! which is best!
