Abaco dbx mass air flow meters
Has anyone seen these at jegs; http://www.jegs.com/p/ABACO/Abaco-DB...72320/10002/-1; Is there any chance they could be used to replace the factory mafs on '86-'89 maf 3rd gens or their available auto parts replacements?
Re: Abaco dbx mass air flow meters
They list an adapter harness for the 89 Trans Am so you probably can get it mounted.
http://www.jegs.com/i/ABACO/039/AB-P...ductId=1272320
Guest
Posts: n/a
That is half the problem with the TPI MAF system. The other half is the gm/sec limitation in the ecm. That meter will just allow you to pretty much flow as much as you need to but it will all be fueled by the PE v RPM table just like many others are doing who run MAF and a lot of HP.
Hotrodboba400
12-10-2019 07:07 PM
