UMI LCA's and panhard bar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
I just installed my LCA's and panhard bar today took maybe an hour and a half to get done everthing fit great the directions were spot on , rear end feels firmer yet smoother over bumps , can't wait to install my UMI SFC's in the next couple weeks . when I'm all done Ill post some pics.
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: UMI LCA's and panhard bar
Did you get the adjustable ones? Those are the ones i'm looking into getting... To re-center the rear.
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
so how is the ride any better?
Engine: 355 SBC
rearend feels much better , after I get the SFC's in I'm gonna focus on the front end not sure if I'm gonna get new control arms or just new bushings yet. any recommendations are welcome .
Car: 1985 Pontiac Trans Am
I cant wait to drive my car its been 2 years.I installed the same solid UMI set and the subframe connecters.I installed new bushing in the stock a arms spohn sway bars front and rear and UMI steering brace.I cant wait to wait to drive it.The UMI subframe connectors are nice.I suggest if u do them yourself u get some small steel shims when welding them up.I have done 2 sets.The shims make it easier to fill any contact voids from the subframe to the connectors.
darwinprice
17
10-11-2015 11:51 PM
LT1Formula
10-08-2015 08:34 PM
