Problems with Scat Cranks?
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
I had a 383 lt1 in my bird had a forged scat crank in it.
when i was cruisin to austin i noticed a loss in oil pressure then heard a knocking noise "spun a bearing". I shut it down quick and towed it back found my oil pump mounting flange cracked in half and a bunch of metal flake in my oil. figured just needed to rebearing it but when i looked closer i also found one of the bobweights on my crank is coming off.
It isnt completely off but i can see at the base of it where it is seporating from the crank.
anyone else have a problem like this? a few weeks before this happend i found a broken main cap bolt right next to this weight im guessing it was causing a vibration that caused the bolt to break... i didnt notice it at that point in time though.
Engine: 383 LT1
Re: Problems with Scat Cranks?
I could see improper machining causing the crank to snap in half but i dont think that would cause the bobweight to come off like that.
Balancing was done at a local austin shop with a good reputation for quality.
Engine: 383 LT1
mine isnt broken like that it looks like its seporating at the base but has not cracked off like that.
Car: 86 Iroc 383 carb, 97 T/A WS6
Yeah I think your block needs line bored. What were your bearing clearances like? I would definitely pull the crank and have someone check the journal alignment.
Scat cranks are fine. Eagles do tend to balance better tho. But about all of your crank manufacturers stuff comes from China. Unless its a billet crank or something custom. The only difference is where the machining is done. Most all crankshaft failures are due to improper balancing, blocks that require line boring, or loose fitting balancers. Which is mostly the fault of the installer not the crank company. I will say that the few defective cranks I have seen from the main manufacturers, are mainly out of round less than .0001" which is actually in spec. But some people are just too picky. The only bad one I have seen in a while was an Eagle 4" stroke crank that was really a 3.75" stroke. It was boxed and stamped wrong. You have nothing to worry about running that Scat.
Seth
Seth
downsouthboy
08-29-2015 11:29 AM
355tpipickup
08-27-2015 08:13 AM
LT1Formula
08-20-2015 09:36 PM
