hotpart.com(j&m) vs. umi lca brackets
Car: 88 iroc-z
Engine: 5.7 zz4
Transmission: megaraptor 700r4
Axle/Gears: 3.73 10 bolt posi
hi guys , anybody using or try the lca brackets from hotpart.com??
how do they compare to umi? do the umi still have fitting issues?
thanks for any help....
Re: hotpart.com(j&m) vs. umi lca brackets
Hello,
Thanks for the interest
We do not have any fitting issues with our brackets, we have sold hundreds of sets with no issues unless you have a 9-Bolt.
If you have any questions please ask, we are also running a 10% off sale on all our items until September 15th
Thank you,
Ryan
Thank you,
Ryan
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
Hello,
Thank you,
Ryan
Thank you,
Ryan
i got the bolt in LCA relocation brackets from UMI... got the bolt in bc they are stronger than the weld in and arent permanent... they will be permanent when i replace the rear. i have a infamous ausi 9bolt... had no real fitment problems... had to be massaged into place with a mallet. good product tho
LT1Formula
10-08-2015 08:34 PM
