Lightest, strongest, best K-members
1 Post
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
I have an 86 Iroc-Z that I am trying to make handle as well as i can. Which Brand K-Member is best for handling.
Spohn Performance
Pa Racing
BMR Performance
any others that anyone knows of?
Spohn Performance
Pa Racing
BMR Performance
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Lightest, strongest, best K-members
What makes you think any of those K members are going to have any effect on how your car handles???
Why would you want to spend $500+ on a k-member, when I don't see shocks or springs in your modifications yet?
1 Post
Car: Iroc
Engine: 350 4-bolt
hahaha. I know. Your totally right, but i want to lighten the front of my car up as much as i can before going for springs. Plus I hate lowered Irocs. Its got new shocks so im not gonna go buy others right now. And i would get Koni yellows, which are a total of like 700 dollars.
aftermarket K-members are lighter and stiffer than stock. Lighter means closer to 50/50 and stiffer means... well.... stiffer. I figured it would be a good upgrade and worthwhile since im going to be swapping a 350 in. I'll do it all at the same time.
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
you could relocate the battery to the trunk or back seat area ( if you don't need a back seat)........that would help in the 50/50 dept......
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
Aluminum heads, water pump, and a little metal out of the cylinders (350) would get you closer to 50/50 too.....
I got mine weighed a couple years ago, and I'm at 52/48 distribution with T-tops off the car, the 2x12" subwoofer board in the back, no spare tire. That was also with A/C removed (but I have installed again), alum heads, intake.
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
A K member would be the very last thing on my mind if I were making an IROC to handle. The stock unit is pretty light as it is, the majority of the weight saved by doing a K member comes from installing a steering rack, and you'll end up losing turning radius; exactly NOT what you're after here. If I were looking into doing up a Camaro for handling one of the first things I would be after would be a good cage, these cars are pretty flimsy and while sub frame connectors help a good cage will do alot more for them. Also whatever you do stay away from a coilover setup on these cars. Coilovers are nice for drag racing but they have no place in track racing, the cars just aren't built to handle it.
1 Post
Car: Iroc
Engine: 350 4-bolt
what did you do to get to 52/48. Thats really good. And i guess i won't bother with a K-member if they really aren't that heavy in the first place.
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
if you are going for handling.... i wouldnt put a k member in a f body.
its more of a drag piece, IMO. save a few pounds and clears up a ton of room for various engines and headers.....
A tubular K-member is a must when going for a LSX swap (Saves a lot of headache) But only weighs about 9 pounds less than stock. I do think it helped the handling on the car though, steering response seems quicker, more "Sure" if you know what I mean. If you are looking for weight savings, there are many much cheaper and easier mods...
NBrehm
08-05-2015 07:57 PM
