Summit Racing branded parts
Car: 1985 Camaro Z28
Engine: 5.7 Liter
Axle/Gears: 10 bolt 3.55 POSI
Is the quality of summit brand engine parts up to par with other well known auto part brands?
Any feedback will be helpful.
Thanks,
Joey
Thanks,
Joey
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
Re: Summit Racing branded parts
I know Mallory dose there ignition parts. Adam :-)
Engine: 5.7 Liter
I am planning on rebuilding my 305. If I use a summit valvetrain and intake instead of a comp cams xtreme energy grind and an edelbrock performer, I should be ok?
I am on an extremely limited budget so any money saved is helpful to me.
I am also planning on using World Products S/R Torquer Heads with 58cc chambers. any feedback on those?
Thanks for your help,
Joey
Joey
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Joey
Joey
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
i remember reading an article in one of the summit mag's about "Summit's" brand. They were explaining that they would not put their name on a cheaply made product because that could ruin their reputation. So i would assume that their brand is of good quality. If you notice a lot of their brand stuff looks similar to other top quality brand items. i bought a summit muffler from them once, looks exactly like a flowmaster, installed... sounded just like a flowmaster for $32 bucks compared to the flowmasters $80.
Car: 91 Z28
Engine: 5.7 L98
Transmission: 700r-4
Axle/Gears: 3.43
If your on a budget, Summit is the way to go. Their products hold up well. The only time you would need to spend outragous amounts of money is if your planning on doing all out racing. They wouldn't waste time making their products if they didn't meet certain standards. I've rebuilt 3 motors using all Summit stuff with no problems 80,000 miles down the road for 1 engine. Still runs perfect! So, I recommend.
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
i know the cam cards at least used to have "CRANE CAMS" down in the corner lol. i have some of their adjustable rear shocks on a friends car and know someone who ran one of their cams. its all good stuff
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Just ordered the Summit "Vortec" heads, they have better specs than gmpp vortecs at half the price fully assembled.
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
I Installed two of the Summit Branded ring and pinion sets in my Suburban. So far so good, I'll need to get back to you once I change out the breakin oil.
Made in India, metal seemed softer than normal.
Car: '84 Z28, '86 IROC
Engine: 305, 406
Transmission: T5, Super T10
Axle/Gears: 3.23, 4.10 Posi
the only problem i've had with summit stuff is i put a cam in my motor once and it wiped a lobe right off of it in about 100 miles but that could've been anything. everything else i've used has been great. i just got one of there ignition kits (box is made by mallory) for my 406 drag motor and it works great. i'd always be confident in their parts
Car: 84
Engine: 360 210 alumium heads
Transmission: th350 3600 stall w/shift kit
Axle/Gears: floater Ford 9" 4.56 full Lw spool
I have used Many of there parts.. as in shocks,valve covers roller rockers,cam, fuel pump,mufflers and much more. Id say its all good stuff. I'm proud of my summit parts.
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Their Pro Star knock offs are really close to the real thing and surprisingly light for being a 1 piece rim. My buddy has them mounted on his Buick for his street tires and look just like the real Welds that he has his slicks on. You just cant beat the price.
Kecin
Kecin
Car: 91 RS
Axle/Gears: 3.45
i bought some stuff from them also, here and there. the most recent thing i bought were tie rod ends, cheaper than all the other ones, but looked just like em. wouldnt be able to tell them apart from moog or any other. and so far theyve been holdin up very very well
summit brand's are good in my book. same thing with ordering stuff from them no matter what brand
Car: 1982 Camaro Z28
Engine: 4bbl 305
Axle/Gears: 10 bolt posi
I needed tools quick, so i bought from them, it was the cheapest crap ive ever seen. Complete garbage, then got a job at Snap-On and thats all i have now. Their parts are up to par though. Great stuff. Saves money when money isnt there. But i do enjoy the brand names
Car: 1990 Firebird
Engine: 600 hp 353.4 CI
Transmission: TH-350/B&M3000
Axle/Gears: 10 bolt 3.23
I'd have to agree with cmgrinn, I rebuilt my 350 using all summit parts and never had a problem. Summit parts are definately great for budget builds!
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
I have never had a reliability problem with any of the summit brand parts I have bought, but I did send back a set of thier aluminum roller rockers, they were the really cheap ones and weighed a metric ton, they also would not clear a big valve spring without significant grinding. So I just exchanged them for harland sharp. They have excellent customer service. I just recently bought a summit 140 gph electric fuel pump to replace my holley 110(blue) and the summit pump is not nearly as loud and works well.
I have had a billion problems with used parts though, used parts are great if you pay very close attention to what you are buying. It only takes one junk used part to wipe out any savings of many other good used parts.
Car: 1991 RS
Engine: 305 LO3
Axle/Gears: 2.73's : (
Joey
Joey
I also am just finishing up installing a set of World Products 305 heads on my LO3. I will let you know how they are once I get it on the road. Probably sometime this weekend.
Car: '89 IROC-Z
Engine: LSx
This is still the case, I bought a Summit Cam/Lifter/Springs/Retainers for $150 and the card said Crane Camshafts in the lower left hand corner. Half the price for the same thing, you decide
Terrell351
06-13-2021 01:13 PM
