B&M SHIFTER
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Re: B&M SHIFTER
The only ratchet shifter I know of for the 82-92 Camaro's is the B&M Mega Shifter. I love mine. The shifts act like a ratcheting action. Put it in 1st..push it (ratchet) into 2nd...and so on. Also..from Drive...down to 1st It also locks it out from going into reverse. But to warn you....it's a VERY firm shifter.....I think it would suck on a daily driver.
The installation is a PITA. It's made cheaply....and you have to cut your factory wiring....
Axle/Gears: '01 3.42 10 bolt
Re: B&M SHIFTER
i use mine in my daily driver and love it. been using it for upwards of close to 4 years now. i have mine hooked up without the relay.
as stated above, it is a firm shifter. it loosens a little with time. once you get used to it, it's not a big deal.
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Re: B&M SHIFTER
YES
Later
Later
Car: 92 25th Anniversary RS
Engine: 305ci 5.0L V8
Re: B&M SHIFTER
i have also been thinkin about getting a b&m after my car is pretty much done. im thinkin of getting the console megashifter (it fits right into the console of a third gen). they look great and from what i see here, they work great too!
Car: Camaro IROC-Z
Transmission: th700r4
Axle/Gears: 2.77
Re: B&M SHIFTER
Can someone explain how I hook up the relay to this shifter ?
I got green/white,purple,ltgreen,ltblue,orngblk,blkwht wires
THANKS// Andreas
THANKS// Andreas
