Pro Comp Cyl Heads
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
Pro Comp Cyl Heads
i found a set of pro comp assemebled aluminum heads for $700 for a pair. i was thinking of getting them but i thought of asking about pro comp products. are pro comp product good or are they junk?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Pro Comp Cyl Heads
total junk, dont buy them
Engine: engineless
oh ok.
whats so wrong with them? do they break fairly easy? bad seals?
there are quite a few posts around here about them, the quality is very poor,
some people seem to think the are great, but just about everyone else will tell you they are junk, i heard that some need a valve job, right out of the box to get them to in spec, and they dont make the flow numbers or power they are advertised to make
Engine: engineless
oh ok thanks. ill check around for the posts.
Car: 86 Iroc 383 carb, 97 T/A WS6
I sell tons of procomp heads at work and I have a mildly ported set on a 383 thats going in my iroc right now. For the money you cant got wrong, the only thing I would recommend is to buy a bare set and assemble them with quality components. When those heads came out a few years ago they had there share of problems but they have come way better with there quality control and are actually using SBI seats and bronze guides in the heads, as far as a budget aluminum head goes you cant go wrong. Most of these people that say these are total junk havent even seen or owned a set. I have some pics of mine if you would pm me Ill email them to you. Again I sell probably 100 or more sets of SBC procomps each month and never get calls about defects or anything. But in the end you always get what you pay for, a set of Dart, RHS, Brodix, AFR, etc would probably be better but if you shooting for 500hp or less on a budget there not a bad choice.
$.02
Seth
$.02
Seth
I recenty purchased a set of procomp 210cc heads the casting the casting are roughf and dont flow what they advertise but after 16 hours of porting I gained almost 20 numbers over advertised
ambainb
04-25-2016 09:21 PM
355tpipickup
Alternative Port EFI Intakes
08-29-2015 10:47 PM
mz92274
08-25-2015 08:47 AM
