projector headlight conversion
Car: 91 Camaro RS
Engine: 3.1L MFI
Transmission: Hydra-Matic 4L60
i bought these lights for my 91 rs http://images.channeladvisor.com/Sel...s/3/LHP4X6.jpg
but they flicker back and forth between the low and high beam...any advice?
Car: 91 Camaro RS
Engine: 3.1L MFI
Re: projector headlight conversion
i checked all the connections and there fine. i heard that the headlights could be drawing to much power from the circuit, and that a new circuit breaker could fix it. or perhaps a new wiring harness.
did you change the wires around? if you notice in that diagram they have to be rotated basically i had the h4 conversion which was the same thing i now have HID's and they are awesome
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
When do they flicker? On hi or low beam? If they do it only on hi-beam, then it is likely that the "drawing to much power" assessment is correct. I had the same issue when I converted to H-4 headlamps. You need to rewire to pull directly from the battery--otherwise you will eventually smoke your headlamp switch. APC has a harness for this, and there is also a "how-to" in the tech articles if you want to do it yourself. The APC harness has breakers with it, but I recommend you also install a heavier gage power wire with a maxi fuse in place of the what comes with the APC kit--I burned mine up in under 10 minutes on hi-beam. Side benefits to this conversion include a brighter light regardless of whether you convert to H-4's or not. Hope that helps.
Car: 91 Camaro RS
Engine: 3.1L MFI
where is the how to article...and where can i get the fuse?
Article is in the Technical Articles section, go to www.thirdgen.org (the homepage) and then click on the "Technical Articles" link. Fuses can be bought at automotive supply stores, AKA "any parts store"
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
Where did you guys get your kits from? Do you recommend any in particular? Or are they just the square headlights you can get on ebay with h4 bulbs?
I got my housings from here http://www.rallylights.com.
Item #H65451. Set 165mm Rectangular ECE Conversion Headlamps. Two Hi/Lo beam with 60/55w H4 Bulb and two Hi beam with 55w H1 bulbs and adapters
Then I bought 2 HID kits, one H1 kit, and then one dual beam H4 kit, on ebay.
