Looking for New Car Alarm, need advice
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
Hello, I want to hook up a alarm system which i can self install. But after looking through so many diffrent alarms on ebay im not sure which one to get and which ones to stay away from. If anyone knows which is a good car alarm for my 84 camaro that would be great. If you have a alarm and are very happy with it and you did a self install please let me know.
also if i did have a pro install how much does that very. Thanks
![your welcome](https://www.thirdgen.org/forums/images/smilies/welcome.gif)
I was going to buy this, does this sound like a good thing to add to my ride? sounds sweet.
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=015
![idiot](https://www.thirdgen.org/forums/images/smilies/idiot.gif)
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Re: Looking for New Car Alarm, need advice
Get something with a 2-Way remote. Viper is a good choice. If you install it yourself, stealth it. Tuck all the wires in factory loom. When you cut a zip tie to run a new wire, replace it. The more factory it looks the harder it is to kill your alarm. Also, mount the sirens in odd places. Inside the center console, in the rear panelling of the trunk, etc. Same with the alarm unit and the battery backup.
Edit: Remember, a starter kill can be bypassed with a screwdriver. You want an ignition kill or a fuel rail kill as well.
Engine: V8 350 ci
Thanks for the reply, yes i think i might go with viper, also i see allot of alarms with remote start, it looks difficult to install, should i get one with or without or is it just preference.![crazy](https://www.thirdgen.org/forums/images/smilies/crazy.gif)
also, the ignition kill, do you know of a good one that works and not too hard to install, I had my last ride stolen, and im not gonna have this one stolen thats for sure if you catch my drift.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
i used an ebay alarm on my stealth and i learned not to buy alarm systems from ebay, the remote fell apart in two years.
Axle/Gears: 3.27 BW
Just wire a relay into one of the wires that goes into your coil (not too sure on this one, haven't done it yet) and have the alarm open the connection so the coil doesn't send out power.
Car: 85 camaro z28
Transmission: auto to manaul
a kill switch is a lot better then a alarm, if u ask me. i had a call stolen with a viper alarm.
Engine: V8 350 ci
![i agree](https://www.thirdgen.org/forums/images/smilies/iagree.gif)
![thank you](https://www.thirdgen.org/forums/images/smilies/thanks.gif)
Engine: V8 350 ci
IF you can please take a look at this kill switch, is this the type you would recommend, it seems like a good item. please let me know what you think.
Kill switch Link
http://cgi.ebay.com/ebaymotors/ws/eB...link:middle:us
Kill switch Link
Car: numerous
Engine: ls1, others
My question would be, how to mount a kill switch so it does not look like a kill switch?
I'm happy w/ my Code Alarm, I think its a CA-150. I also added a glass breakage sensor (since the shock sensor isn't too sensitive, plus the t-tops). Make sure to put pins in the hood/trunk as well. I hooked it up to the horn and a siren (mounted by the battery). Lastly, I put a piezo in the center vent to make it slightly painful to be in the car with it going off. As everyone said, installation is key, and add kill switches!!!
Car: 1987 Camaro
Engine: 5.7
I have an audiovox/Prestige alarm with a 2way remote and remote starter which displays opens doors, when car is remote started with timer and temperature and auto start timers, but anyways its a really nice alarm and ive been quiet happy with it, But I would like to add a kill switch and microwave sensor.
Does anyone know how to make the hood display as the hood open and not as a door? it has the icon for the hood but when the hoods open it shows as a door?
http://www.caraudiocentral.net/
I'm sure the icons on the remote are just indicators for "zones" on the alarm brain. All you have to do is find out which zone indicates the hood icon, and wire the hood pin to that zone instead of the zone it is currently wired to.
Car: 91 RS
Engine: 305 TBI
Transmission: Stock auto
Engine: V8 350 ci
Kill switch Link
Kill switch Link
![bs](https://www.thirdgen.org/forums/images/smilies/bs.gif)
i would go viper.. i have one and am very happy with it, its a rather pricey one at around 500 tho.. its about 2 years old id say.. maybe more.. the last kid who owned the car installed it.. has remote start.. in a couple months im getting one witht the display.. the alarm should be able to do ignition lock out as well.. viper is the way to go even tho its pricey if u realy want to protect your car
Car: 87 GTA
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Check out a Car Gard CG 1-AC with gem lock. It secures the ignition switch so there is no way to pop it and take a joy ride. I use one along with a cheap entry alarm with red blinking l.e.d.
Car: 87 GTA
They weren't allowed to video/take pictures DURING the install, and they mentioned fake wires being installed. Basically, the harness had like 30 wires, but a lot of them did ZERO. So the chances of bypassing it, with the wires cut/whatever, was impossible.
Really cool!
That's one advantage to my POS I guess...nobody would wanna steal it!
![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
theshackle
03-05-2017 06:37 PM
