Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
royal purple is bad????
Old 07-25-2007 | 05:54 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I heard there are some bad things about royal purple oil. Is this true and plz help me. I'm so new to this crap
Old 07-25-2007 | 06:35 PM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
Re: royal purple is bad????
Royal Purple is the "vogue" stuff right now. It's fine. So is Red Line (which I use), Amsoil and Mobil 1 synth.
Old 07-25-2007 | 06:41 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
ok well i just herd it has no detergents or w/e. didnt know if it mattered or what
Old 07-25-2007 | 08:04 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Try reading up some at bobistheoilguy.com.
They have lots of good oil info there.
Old 07-25-2007 | 08:58 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
well i heard that it doesnt have any detergents in it? Isn't that bad for the car or am I crazy?
Old 07-25-2007 | 10:41 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
... brad i told you if it really matters my job stocks amsoil or you really could just buy regular dinosaur oil.... it ownt hurt your car, remember its a chevy if it aint smoking you're walking
Old 07-25-2007 | 10:47 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
also try to look and make sure it has a high pressure additive zync, i think its ddzp or something like that. you just have to make sure it has that high pressure crap.
On a side thought you could run rotella t i know that stuff has the high pressure package
Old 07-25-2007 | 10:51 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
ok well how much does ur job sell it for???
Old 07-26-2007 | 01:24 AM
fastcar06's Avatar
Car: 1991 pro street formula
Engine: 355
Transmission: turbo 350 w/ 3200 stall
Axle/Gears: 9" ford detroit locker w/ 456
a buddy of mine at work put together a motor with the holley intake, cam,etc.. package. wiped out the cam in 20 minutes. called holley and they highly recommended the rotella and a break in lube from gm which i'm not familiar with.
Old 07-26-2007 | 09:22 AM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
when building a motor, you need the zinc, hence why you were recommended the diesel oil (but even there the additive are being changed for emissions reasons). If nothing was done specifically for the break-in period, thats why parts were smoked.
Old 07-26-2007 | 12:23 PM
Stephen's Avatar
Car: 87 GTA
Even the synthetic manufacturers will tell you...Break in a new engine on Dyno oil, then switch. Synthetics aren't good for engine break ins.
Old 07-26-2007 | 05:47 PM
Jens J's Avatar
I guess it was a non roller. You have to brake inn these cams at betwen 2000-3000rpms for 20min even with addatives
Old 07-26-2007 | 06:42 PM
91 355 z28's Avatar
i run royal purple in my car and love it no problems.. i have a rebuilt engine broke it in on quaker state and the royal purple doesnt thin out on long trips like regular oil does
Old 08-05-2007 | 10:35 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Detergents are more useful for "dirty old sludgey" engines. That is way on really old engines with lots of sludge, people will add a quart of ATF (Automatic Transmission Fluid) for it's detergent qualities.
But, if you change your oil on a regular basis and using a good synthetic, detergents aren't as important.
While I personally use Mobil 1 (mainly because it's readily availabe where I live and realitively cheaper cost), I have only heard good things about Royal Purple. If it was readily available at the same price as Mobil 1 (where I live), I would have no hesitation to use it.
Old 08-06-2007 | 09:23 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
i used straight quaker 30 til 1000 miles then switched to 10 30 quaker at 10k miles i switched to royal purple.
Old 08-07-2007 | 01:31 PM
Rick Routzahn's Avatar
I have Pennzoil Platinum --- is that good to use?
Old 08-12-2007 | 12:22 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
If u have a flat teppet style motor a straight 30W diesel oil is the best way to go. It still has the zinc additives which none of the regular ones on the shelf have. I personally use rotella 30W in mine. If u have a roller motor i would highly recommend royal purple.
Old 08-12-2007 | 01:57 AM
Freakazooid52's Avatar
Car: 1986 firebird
Transmission: THM350
also with flattappets you can use Valvoline VR1 (readliy avalible from jegs) ive also seen them at murrays/autozone by me but only n 20w-50 but 10w-30 can be had from jegs.
got 90,000 miles on a flat tappet with it and no problems.
Hotrodboba400
12-10-2019 08:07 PM
3rdgenkindagal
Aftermarket Vendor Review
25
10-21-2015 10:32 AM
Cleotiz
09-16-2015 09:02 AM
gta892000
09-16-2015 01:40 AM
Hotrodboba400
09-02-2015 08:28 PM
