Summit Distributor
Summit Distributor
http://store.summitracing.com/partde...5&autoview=sku
Replaced my old distributor when I was on the dyno and picked up 20 RWHP and around 22 RWTQ just by switching it out. Looks very nice and alot cheaper than MSD. A good pick IMO
Car: 1988 Camaro 11.08s / 130.5mph
Engine: 383 HSR
Transmission: 700 R4
Axle/Gears: 9-bolt 3.27
Re: Summit Distributor
Good news.
I´m thinking of replacing my distributor too.
Is it a direkt replacement for the stock one?
Was your old one badly worn or was it something wrong with it?
Was the car running ok before the swap?
Many questions, but it is interesting to know if you reached the good result because of a very bad stock dist or if the new one is so much better than a normally worn stock.
Car: 1986 firebird
Transmission: THM350
Good news.
So yes, if you have a CC dist with plugs on the front like that one, you can drop it in and go.
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
Another cheap alternative is to buy a new cap and rotor and rebuild kit from the dealer. I think I spent around $100. I rebuilt mine with an MSD cap and rotor and parts from the dealer. It was way easier than I thought and I got the satisfaction of rebuilding the alternator myself. The only tools required were a hammer, punch, wire brush, and screwdriver. Not sure if anyone is interested. Just food for thought.
Engine: 383 HSR
Another alternative is the D.U.I. distributor and coil.
A little more expensive but do you think it is worth it?
It looks real good when I read about it.
/JWi
/JWi
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
summit HEI dizzy's only have 16* mechanical advance correct?
nothing like chopping down the mechanical and spiking initial advance
1 Post
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
I think it looks pretty good, kinda tempting me to get one, since i have a shitty accel cap right now
RedLeader289
05-28-2019 01:47 PM
school boy
10-22-2015 11:47 AM
HoosierinWA
10-07-2015 10:15 AM
Damon
09-26-2015 04:29 PM
