Has anyone had problems with a Carter Street pump and running rich?
Car: 2002 SOM z28
I just put on a Carter street pump rated at 6psi and now I may be running rich? Granted the car runs great, but last night I couldn't start my car and it appeared my carb was flooded. My only concern (because others run this pump and love it) is that my stock pump had a little return port (1 in, 1 to carb, and 1 to return line) while this carb only has ports for line from tank and line to carb.
Any one else have issues with this carb?
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
-=ICON Motorsports=-
Car: 1986 Z28
Engine: 355
Transmission: th400
Never had a rich problem with mine
and 6psi is a bit high for a Qjet and I still didn't have the problem
my biggest concern was always vapor lock
a big vacuum on that fuel running next to the headers. but it never seemed to happen
good luck with it.
if it seems to be flooding lower the float level in the carb or put a pressure regulator on it
good luck with it.
theshackle
03-05-2017 06:37 PM
