Overriding governor/restrictor
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
I have purchase a chip from ebay to override the governor/restrictor. I am hesitant to put the chip in. Can anyone give me some advice? Here is the link to the product i have.
http://cgi.ebay.com/ebaymotors/Ponti...QQcmdZViewItem
No offense man, but you just got ripped off.
That chip is going to do nothing for you at all. Just by reading through the item description its obvious its a quack.
Live and Learn
Live and Learn
Axle/Gears: '01 3.42 10 bolt
governor does nothing to regulate speed in thirdgens. it is the limiter in the programming that does it. plus, the firebirds and camaros used the same motors so why wouldn't it work in camaros? plus, the later firebirds with the LT1 and LS1 used different programming than the thirdgens do as well as different ecms. so how is it this chip fits all birds '88-2000?
i agree, i think you got ripped off.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Well, there goes $60 for nothing... lol
May as well have just burnt that money or bought some beer, at least if you bought some beer you would have gotten something out of that money!
Actually beer is a really good deal, its like a 2 for 1 deal. You get drunk AND a hangover
Car: Death Mobile
Engine: 666 c.i.
Your car is "Speed Density" made from 1990-1992. You need a specific memcal for your particular model, engine, transmission & gear ratio and SOMETIMES your specific year (though sometimes a 1990 will work in a 91 or 92) depending on the model.
Simplest thing to do, find some fairly local that has the eprom burning equipment and get them to reprogram your memcal for you. There is no "simple" eprom you can plug it. You need either a memcal or "adapter" with a flash-prom...either way they are not "just a couple of bucks". So the cheapest thing is to find someone to reprogram your memcal (or send it to someone....and wait until it's returned....but your car is undriveable in the meantime.
Engine: V8 305
This is the response from the company:
Hello,
The Accelerator connects to the Coolant Temperature Sensor . It will not remove or overide any governors or limiters, but it will help you reach those speeds faster.
Ebay rules specify that we have to list for specific models.
Thanks again!
Kathy
Hello,
Thanks again!
Kathy
Car: 87 Camaro IROC
well since it actually says nothing about a govener in the auction, it looks like they have done thier due dilligance. from what i can see in his feedback, ppl only get a 5hp gain and thats it. seems also that the seller is into bribing the buyer to leave good feedback. you know i have to say that this is a lesson for you, READ EVERY EBAY AUCTION AND EBAY SELLERS FEEDBACK BEFORE PURCHASE. there are plenty of idiots out there that wanna take advantage of us.
let me sum up "gadgets100" feedback for you. most ppl left positive, but most ppl only said "fast shipping and good instructions", they never said anything about the quality itself (leading me to believe they were bribed). a few left positive feedback with results of over 20hp gains dyno'd and were pleased with shipping and quality. every person who was neutral said that the part didnt do what they wanted or that they were bribed to say good things, some said that they couldnt tell hp gains even tho it was installed properly. and EVERY single negative responce said that it made the engine worse or didnt work at all dyno'd and they tried to bribe the buyer for a good feedback.
thats bad feedback...he should be removed from EBAY as a seller.
all you can do now is pay for it and leave bad feedback, you get what you paid for, and not reading and doing your due dilligance allowed him the win.
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Say you want a mutual withdrawl from the auction. If you give them bad feedback they will just give you bad feedback.
Since it is going to happen might as well get the bad feedback you have coming and keep $60.
unless you have it in hand... in that case sell the sucker to a sucker and cut your losses.
Engine: V8 305
Ya, my fault there for lack of research, does anyone know a good governor override chip that doesn't involve soldering?
Car: 1992 Z03 RS
Engine: (L03) 305TBI
Axle/Gears: bone stock
the VSS is the only thing holding back thirdgens. Not that i would do over 120 or 30 anyways for fear or blowing the engine. You dont get any HP out of it. It just helps you to your grave.
Just for note, none of these cars have the power to actually go a true 180 without many other mods. Maybe with miles of wind up, but that just leads to catastrophy.
- sorry about your luck, - as was stated, you need to research before clicking that key.....
Car: 1987 IROC-Z
Engine: 310 lb9
Transmission: SEMI STOCK 700R4
Axle/Gears: 3.45 9 BOLT
so some 1 said i will blow my motor if i do more than 120-130 mph how is that i and doing 145mph at 3900rpm.
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
umm where do you think the programming gets it's input from? cut out the VSS and you cut out the programming's knowledge of what speed you are going negating speed limiting.
instead of cutting out the vss, which can be used for other purposes, why not just adjust the max speed in the programming. that would be much simpler. as i said, the vss has nothing to do with it. it is the programming.
Car: Death Mobile
Engine: 666 c.i.
The VSS is a required sensor for the ECM. Overriding/disconnecting it is not an option. The only fix, is to get a chip with the "speed limit" set up to the maximum 255 mph.
Car: 87 GTA
$5 (a switch, some wire, and some connectors) and a half hour, and you can get rid of the speed limiter easily...
Speed Limiter bypass
I developed this, shared it with all, and Bradley did the write-up on it, when we first founded TGO.
I still believe it would work on TPI cars as well, as it really only interrupts the signal to the ECM, causing thhe speed limiter to kick in. I just haven't had any reason to try it on a TPI car.
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
Were thrid gen Firebirds goverened? I know the 4th gens were. Or was it just the 5.0's? What about Camaro's?
There's also a paragraph that's says a 30 money back guarantee. You may be able to get your money back. I wouldn't leave feedback until you find out if they'll give you your money back.
Car: 87 GTA
Both my TBI cars were, haven't tried in my GTA TPI...nor will I, unless I wanna die.
Dunno when the governer started (in the year), but I believe the 1LE (police package) cars had no governer.
Car: 87 GTA
We are not discussing the tranny governor.
Car: 1987 Z28
Engine: LG4
My 83 t/a will go 130, maybe 135 if im lucky. The reason is no horsepower not some limiter. Also, my friend has a 89 iroc-z w/350 and it goes bout 155 to 160ish.(ran out of road) We use gps units to acquire our top speed. So carb no limiter, tbi no limiter, tpi no limiter. Though ive seen a 92 rs w/305-auto bounce off 135mph(engine cuts in and out)
Car: 1992 Camaro vert
Engine: 355
Axle/Gears: 10 bolt... not blow up yet
ok so I have a 92 z28 305tpi
which do i put the switch on to get rid of this damb thing?
114mph on the nose everytime and scary as **** when it happens with bucking and other scariness
im tired of freakin civics passin me on I95 goin to the races WTF
so for an older ecm it says use A10
but i have a 7730 so whch one do I use?
BB10 or BB11
if its even possible without chip....
ugh numbers and letters help please help lol
thanks guys and gals
-ken
Engine: 355
does urs have a 7730?
do you thiknk i need the switch from the tranny or the speedometer?
if i do it to the tranny wont it mess with the shift points?
Car: 87 GTA
Well, when I did it to the 92, it was a T5. Besides, our 700R4s aren't electronically controled. The shift points are all internal to the tranny.
Dunno which ECM I had on the TBI or I have on my TPI now.
Car: Death Mobile
Engine: 666 c.i.
If you disable/limit the signal to the ECM from the VSS on an automatic car, it can cause the Torque Convertor to not lock. The tranny cooler only works when the TC is locked so having it "unlocked" can cause pre-mature death to your tranny. So I would NOT do this with an automatic car under any circumstance.
The correct fix is to change the setting inside the eprom. Using "gadgets" to trick the VSS can result in other problems. Such as, if your car is 1989 or later, it has an electronic speedo and without the proper signal from the VSS, the speedo won't work properly.
I doubt the early carb'd ones were...dunno hohw they would even govern a carb'd car.
1LE was not a police package...that was a performance package...no ac fog light delete rear disk brakes baffled gas tank and such...
B4C was the police package.
Car: 87 GTA
How so? The 700R4 isn't electronically controlled by the ECM. It should has nothing to do with the TC lockup, or the cooler. Everything in a 700R4 is MECHANICALLY controlled.
Car: Death Mobile
Engine: 666 c.i.
Please review a wiring diagram if you don't believe me. But I assure you, the ECM on both MAF & SD cars controls the locking of the TC.
If the TC doesn't lockup, the excess slippage will generate excess heat and worst, GM stupidly designed the transmission so fluid only flows through the oil cooler when the TC is locked. This will result in shortening the tranny's life significantly as heat is the biggest enemy of the 4L60/700R4 tranny.
#42
Car: 87 GTA
Interesting...I assume there is an electonic valve in the tranny, that controls thhe fluid movement, into and out of the TC?
On a tranny note...What keeps it from going in to OD, at WOT? C18? Can that be overidden? I think thhe Corvettes didn't have that happen...
#44
Car: Death Mobile
Engine: 666 c.i.
But, once installed, you will be able to accelerate in WOT in 4th gear.
As for the "fluid flowing" when the TC is only locked, there is a modification you can make so fluid will partically flow when the TC isn't locked. There was discussion on this a few years ago on the DIY Prom Board. Do a search on "TC locking" on the DIY Prom Board and you should be able to find it. Conversely, make a post on the Tranny Board on how to make this modification so tranny fluid will flow to the tranny cooler at all times.
#45
Engine: 355
wow
yea so um iv been told that i could get my prom changed and change the speed limiter to 255mph instead of 114mph. i think ill just let my buddy do that for a couple of bux
#46
Car: 87 GTA
I'm jealous of my buddies LS1 3rd gen...
Hook up the laptop, tap a few keys, done! EPROMs are cool. No chip burning, so crawling under the dash, nothing.
I might upgrade my PROM to the EPROM style, one of these days.
#47
Car: Death Mobile
Engine: 666 c.i.
With our cars, I've swapped the stock eprom to a flash prom in the memcal. The flash prom is far better than the stock eprom. The stock eprom can only be erased a few times (somewhere from 15-50) before they become unuseable. And, each time you need to erase them "a little longer" to make there re-program properly. A flash prom like the AT29C256 can be reprogrammed hundreds (or even thousands) of times and don't require any erasing prior to re-programming. The only problem is finding an AT29C256 as Atmel recently stopped making them
BTW, you may want to try this...when I am in "tuning mode", I just shove the ECM up in the passenger side of the dash and use a couple of sponges to hold snuggly it in place. It makes it really easy to access the ECM yet holds it nicely in the dash (instead of laying on the floor).
#48
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
well the speed limiter was low on specific models only. I belive it was decided on tires rating/rim combo's and what type of power plant combo you had... say a 15" rim on a tbi camaro may have a 120 limit? and a tpi 16" may have the 255 mph limit( = no limit ) in the chip. not sure on the specifics but it was along those lines
so what happened with the part?
#49
Car: Death Mobile
Engine: 666 c.i.
