DERALE 700R4 Trans Cooling Pan
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Installed a new Derale trans pan for my 700r4 auto. Problem is that the cooling tubes stick out too far in the front of the pan and you cannot install the two(2) front center mounting bolts without removing the trans crossmember. Needless to say, I was not happy. Just a heads up to let you know that if you are considering buying one,don't.That is, unless you like being #*&@!K*&. Badman
1 Post
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Ehh I've had mine for 6 years now and the one time I had to change it I used a 1/4 extension and socket. Worked perfect.
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
I wish it was that easy. There is no way you can even start the bolt. Poor design. Belive me, I tried every tool . Badman
ambainb
04-25-2016 09:21 PM
Thornburg
08-25-2015 01:46 AM
