Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Everyone with an L98 with the LT4 HOT cam please step in...
Old 11-16-2000 | 06:37 PM
Dan87IROC-Z's Avatar
How has it worked? What performance gains did it give you? What other mods did you have already when you purchased and installed the cam? Thanks
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Old 11-17-2000 | 11:04 AM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Well, I can't exactly tell you what gains I've seen, because I've only put 50 miles on my car since I just put the new engine in. So it'll be a while before I know how it works out in the upper RPM's. But through the mid 3's it's great, I'll let you know more when I do.
Black 88 GTA L98
New engine is in!
ZZ4 bottom end, Edelbrock 6085 heads, LT4 HOT cam, GMPP 1.6 RR's, ported stock TPI, SLP 1 3/4" headers, no cat, Dynomax cat-back
E.T.F.A Member #11
Old 11-17-2000 | 09:30 PM
shawn87gta's Avatar
I considered the LT4 Hot cam, but I went with this Comp cam - HR269 p/n08-502-8. It's similar to the Hot cam, spec's:
.050 218/224
.200 139/145
lift .495/.503 w/1.5's .528/.536 w/1.6's
The primary difference on the Hot cam is duration @.200 - .132/.135. I felt .200 was about where the heads really started to work, so the better duration there was key to my decision.
I replaced an LT4 production cam and the Comp made a big difference, plus I think it will still be a good choice when I upgrade the heads/induction. It makes much more torque and pulls hard until it runs out of air. Nice lopey idle too.
There was no comparison in craftsmanship between the Comp(billet) and LT4 production (welded) cams - if the Hot cam is welded like the production cam, IMO this alone would be enough reason to pay the ~$75 difference.
87 GTA, auto w/2075 stall, 3.27 rear, L98 .020 over,Comp 269HR cam & 1.5 roller tips, ported heads w/3 angle vj & brnz guides, 52mm TB & airfoil, SLP runners, ported plenum, ported intake, Edelbrock TES, AFPR, MSD 6A/Blaster coil, MAF screens, cold-air induction, vortec muffler, heated O2, Ed Wright Fastchip.
Old 11-19-2000 | 12:24 AM
Anyone else????
L98 TPI 350 (5.7L)
Old 11-20-2000 | 10:47 AM
Erik formula L98's Avatar
Tom Keliher used the hotcam in his car, here's his page. http://www.geocities.com/motorcity/garage/2031/
Erik '89 Formula 350 TPI
14.03 @ 96 on motor
12.83 @ 109 w/NOS
http://www.geocities.com/formulal98/
Old 11-22-2000 | 11:39 PM
Come on guys, I know more than just a few of you have this cam or know someone who does.
L98 TPI 350 (5.7L)
Soon to come: LT4 HOT Cam, Air Flow Research 190cc or 195cc Heads, 2800 RPM Stall Converter and SLP 3.70 Rear End Gears.
Old 11-23-2000 | 01:05 AM
Jay87Z's Avatar
Car: 2000 Corvette FRC
Transmission: M6
Not many people use it in our cars because its a high RPM cam, and wouldn't work optimally with a TPI setup.
The LT4 HOT cam will give you gains, but there are aftermarket cams that will get the job done better.
Old 11-23-2000 | 01:11 AM
Like what ones?
L98 TPI 350 (5.7L)
Old 11-24-2000 | 02:33 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
LPE219 cam for one, I'm sure there are lots more. www.lingenfelter.com
lt500r55
09-01-2021 02:30 PM
GTAman
03-15-2019 12:40 PM
80s Poncho
08-19-2015 07:45 PM
1988iroc350tpi
08-14-2015 08:52 PM
anesthes
08-08-2015 10:37 PM
