headers
Car: 91 B4C
I have hooker 2055. I had to keep emissions legal, they went in fairly easy and fit well as far as plugs and ground clearance go. I would have gone long tube if emissions were not an issue as well as ground clearance since it is lowered. I have installed edlebrocks as well and they seemed a little easier to get in and clear everything nicely also. hope this helps
A is always a good thing. The Hooker 2055's are a great choice. Check the following link:
https://www.thirdgen.org/forums/exha...ion-chart.html
JamesC
JamesC
Car: 92 camaro rs
have flowtech headers and they fit fine then i swapped the oil pan to aftermarket one and the y pipe hit the oil pan and had to bend it to fit better
1 Post
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
I have Edelbrock TES headers, They are pretty nice. Had to stay emissions legal that why I got these as well.
I have dart 165 heads, and I think that is my problem. It seams to pitch the headers up and out which makes the flang hit the firewall. The number eight plug hits one of the runners. I wanted to buy one last set, maybee ceramic just did not want to end up wrong combo again.
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Your problem is that you used flow techs... there is a reason those are dirt cheap. Their flanges are machined like aluminum foil. If you get them on and take them off... you might as well toss them because they warp. They are kinda like disposable tupperware.... they can be used for a while, but then eventually you have to throw them away.
Just buy hooker 2055's they have insane quality and a legendary y-pipe.
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
DAMN! i just checked summit for the price on those hooker 2055's, they want around $750 for them!!!
Originally Posted by nelapse
I got a set for $370 shipped from summit, worth every last cent.
i didnt see them without the coating on summit
Car: 1991 GTA Trans Am
Engine: 355 TPI
Transmission: 700R-4
I have Edelbrock TES headers with Ti-tech ceramic coating.
I'd recommend copper gaskets and split-lock header bolts on any kind of header. Have them on mine and haven't had a leak since putting them on. A company called Breslin makes the split-lock bolts if anyone wanted to know.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
i have a set of SLP 1 3/4 shorties and matching y pipe ceramic coated and i love them, they work well, fit well, and look great, and i believe they are stainless steel?
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
Anyone have the hooker 2210's they are a bit cheaper than the 2055's and are full length. Is that better or worse on a third gen?
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
also look in the exhaust board it's all covered in there.Also may want to try a
redformula88
10-14-2015 06:08 PM
