performer rpm intake
Car: 1988 Firebird Formula t-tops
Engine: 350 60 over...400 HP
Transmission: 700 r4 transgo shift kit
Axle/Gears: stock...373?
Will a performer rpm intake fit under a 3rd gen firebird formula hood? thanks..
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
I had a performer RPM airgap with a Holley street avenger carb under my camaro B4 my new hood, I wouldn't think your hood would have any less clearance, i believe the air gap is a little taller than an rpm actually. I had to get a drop base K&N but it fit. I'm sure you wouldn't have any problems as long as you are willing to get the drop base filter
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
I have one with a edelbrock carb under my 84 Camaro hood with a duel inlet housing with room left.
Good luck,
Mike
Good luck,
Mike
How much power can be lost using a drop base filter?
edelbrock....performer series.
This "L-88", air cleaner base is what I use on my Firebird.
Use a Edelbrock 1/2" air cleaner spacer so it clears the carb fuel inlet fitting. (banjo fitting) if you're using a HEI you'll have to carve a flat on the back of the air cleaner base to clear the HEI cap.
Use a 14x 3" air filter.
You can get this L-88 air cleaner base from Noah performance.
PN is 2193b
If you want to use a holley the choke horn needs to be removed. the Edelbrock is fine as is.
noahhomepage
You can buy just the base itself and use most performance lids, or buy the complete aircleaner (lid and base)
Use Edelbrock#8093 1/2" spacer.
This set up allow the most possible hood clearence witout flow restriction. There is even enough room for a 1/2" nitrous plate. This air cleaner base hugs down around the carb. You probabily will need to rework the throttle cable bracket lower. I made a custom one from an old GM throttle cable bracket and some sheet metal a few scres and some welding.
PN is 2193b
noahhomepage
did you mean this 2195B? if you can, send me a direct link to the air cleaner. and is your intake an RPM and is it a stock firebird hood? Thanks
Yes my hood is stock Fbird and the intake is a RPM airgap.
i've use both holley and Edelbrock carbs. This air cleaner base even fits a Qjet.
do you lose any power by using a drop base filter like that? and can i use my acutal 14x3 filter on that base? and i most likely am suppose to get the one for the small block right?
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
No you don;t loose power. That base was designed to support 560+hp (69L88 Zl1) no you don't need the SB one.
There is enough space. Holleys require removal of the taller choke horn.
Car: 85 Pontiac Trans Am
Engine: wouldnt you lilke to know??
Transmission: TH350 Built to the hilt
Axle/Gears: 4:10 Gears Moser Axle Auburn Posi
ive got a performer edlebrock 600 carb....pn 1406... with the signature series air cleaner set up base... and i have a 1 1/2 or 2" universal k&n 14 in filter and the K&n extreme filter the one that acts like a lid /air cleaner i have a midrange weiand dual plane intake and about a half inch adapter underneath my carb i have no clearance problems.. i did for a lil while .. just the edge of the cleaner was rubbing one of the braces under my hood so i shaved that spot out of the brace and viola no clearance problems...
they make the same air cleaner for big blocks and small blocks. What one do I need to buy?
This part is from the 60's. You have to modify it to fit but it allows the most hood clearance and its specific shape is much more scienced out for max air flow than typical aftermarkets drop base air cleaners. buy which ever one you want. I use a BBC one on my SB. You don't have enough motor to max this one out.
Originally Posted by George
You need a certain amount of space between the top of the carb and the cleaner o/wise it screws up the air flow into the carb.
Car: 85 Berlinetta F41
Engine: 355
Transmission: TH700
rjmcgee ... can you tell me which edelbrock part you have?? my old edelbrock drop base hit the float bowls... are you using a spacer to lift the drop base???? thanks in advance
for you that have camaros....I know that all kinds of intake carb air filter combos will fit...ON CAMAROS. A firebird has a completely different slope to the hood. I have a performer rpm on now with a 3 inch air cleaner and it sticks through the top of my hood atleast an inch. i cut a hole in a stock firebird hood for a temporay solution. So if you have a firebird and you are running an rpm under a formula hood or a stock hood your advice is greatly appreciated. Thanks.
ohhh...don't worry I didn't butcher my formula hood...no way. I have a few 3rd gen firebirds for parts and i just took a base model hood off one of those cars and butchered it. And I still have the intentions of completing the cowl induction on that hood. But I want my formula hood on there for now because it matches the paint and it's a formula hood...they are sweet. When I go to have the car painted i'll probably get both hoods painted (the cowl hood and the formula hood) and if i want to swap them off everynow and then...then i can.
theshackle
09-17-2020 08:26 AM
