SFC
Car: C1500
SFC
Has anybody tried Jegster subframe connectors?
If you get bolt in sfc's then do you have to drill holes, or can you use existing holes?
1985 Camaro IROC-Z LB9
1989 Pontiac Firebird
Formula W6S LO3 TBI 305
-180 degree stat
-Hooker Cat-Back
-180 degree stat
-Hooker Cat-Back
never used the bolt ins. i'd go for the weld in SFC's. that seems to be what most people on here have in their cars.
-=ICON MOTORSPORTS=-
1st & 3rd
1st & 3rd
If you drive you car hard enough to merit the need for subframe connectors, even if it's not driven hard on a daily basis, the stress transferred through the connectors is still going to wallow out the bolt holes and cause problems down the road. Weld in subframe connectors such as mine from Global West, are designed to have as large a foot print as possible where they are welded to transfer this stress over a larger, stronger area. Also they work great as a jacking point in a pinch. :0)
Car: C1500
I'm not going to weld those things onto my car. I just want bolt ins. It's not going to be driven all the much on a regular basis, well probably not.
-180 degree stat
-Hooker Cat-Back
-180 degree stat
-Hooker Cat-Back
I think you have to drill holes. There aren't many good places with existing holes under the car for SFCs to bolt to.
I know my "bolt-on" driveshaft loop requires holes to be drilled, so don't let the word fool you.
Keith5, I have to agree with the others about welding your SFCs. Bolting them will require drilling holes in the sub frames. As you drive the car the body will still try to twist and the bolts will loosen and oblong the holes in the sub frame. Then it will be even harder to keep the connectors doing their job if the holes are not perfect or become slotted.
For your other question I have not tried Jegs connectors. I used Alston connectors on both of my cars. I also believe SSM makes a very good set unless you have a convertible.
88 IROC convertible
-=ICON Motorsports=-
88 IROC convertible
odin65, how big are the holes about?
keith don't worry about the holes because of what these gents say won't happen period.
i have bolts from comp engir. and they have been in 4 2 1/2 yrs w/ no signs of rounding
check my sig. 4 durability. also look back futher in this section we have had an extensive discussion on this topic!
92 F-BIRd FORMULA T-TOP (WHITEKNIGHT) 5.7L-98,700R4B&MSATURDAY NIGHT
SPECIALTRANS 2500STALL,54MM-AS&M TB-PORTPLENT,LARGETUBRUN,
UNDER PULLEYS K&NCOLD AIR KIT,160THERMO,ELDB HEADERS W/3 1/2 Y PIPE 2 RINO CAT 2 4INCH PIPE 2 FLOW,
MSDDIST,6AL,8MMWIRES.
2BLASTERCOIL.ACCELL PLUGS
CUSTOM FASTCHIP BY ED WRIGHT,AUBERN POSI W/ RICHMOND 3.73 AND SPLINES,TUBE FRAME CONNEC
PST KIT.1LE BRAKE KIT! MANY MORE MODS FORESEEN IN MY ERA!13.38ET @ 109.75MPH
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
luvofjah
09-26-2015 08:28 PM
