Blueprint brand Engines
Car: 08 G8 GT, 98 Z28, 86 IROC, 85 Z28
I was looking around Jeg's website today and noticed they had some new crate engines on their website. They are called Blueprint Engines and have a 2 year warranty. One of them claims 405 HP and comes with everything even the intake manifold; only $2899.99. They even say their dyno'd and come with the dyno sheets. Maybe I misread something, but that sounds like a deal.
Here's a link to the page. Just look under Blueprint Engines.
JEGS High Performance - Engines - Assembled / Ready-to-Run
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
yeah i just saw them too
i like the world products one
seems these crate setups are the way to go, warranty, all setup, dyno'ed,
not bad
not bad
FOR ENGINE NOTED ABOVE:
Block:
# 4-bolt main block - Driver's side dipstick
# Square and parallel decked
# Align honed main bearing bore
# Cylinders are sonic tested for thickness
# Cylinders honed on a computer controlled machine to within .0002'' straightness and roundness
Rotating Assembly:
# SCAT cast iron crankshaft
# Keith Black hypereutectic pistons
# Hastings Moly rings
# Balanced rotating assembly
# Melling high volume oil pump
# Flat tappet solid lifter camshaft
# Heavy duty double roller timing set
Cylinder Heads:
# GM 305 straight plug heads
# Hardened retainers and 1.437'' diameter valve springs
# 2.02'' swirl polished intake valves
# 1.60'' swirl polished exhaust valves
# Hardened pushrods
Extras:
# Aluminum single plane high-rise intake manifold
# Steel circle track valve covers
# 7-quart left turn baffled oil pan
# Professional Products harmonic balancer
# 12:1 compression
Horsepower: 400
Torque: 392
ALSO!
They not only have long blocks, but they also have full crate engines including carburetor. They even have a series that include a single-plane EFI setup with fuel rails, lines, distributor and wires....everything but the computer
Block:
Rotating Assembly:
Cylinder Heads:
# Hardened pushrods
Extras:
# 12:1 compression
Horsepower: 400
Torque: 392
ALSO!
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
the two 355's listed above the 383 were $4k and $5K.. I think it may have been a typo, seemed too good to be true.
I don't think it's a typo. The more expensive motors are roller engines and they have forged parts as well.
The 385 HP one sounds like the one I might go with. I'm gonna give Jegs a call and see if when they say dyno if that means that engine has been dynoed and broken in or if an engine just like that one was dynoed and made xxx amount of HP.
Car: 04 gtp, 96 f150, 88 camaro
Engine: 3.8sc, 5.0, 385ci
Transmission: auto, 5speed, 700r4
Contact Blueprint Engines at,
Crate Engines, Stroker Engines & other Custom High Performance Engines - BluePrint Engines.com
1-800-483-4263
Car: 88iroc
Engine: 355 blueprint engine
Transmission: raptor built 700r4
Axle/Gears: 373
blueprint engines
i bought a 355 base engine and it came with a dyno sheet i called them up for a few questions and they told me mine is 385 horse with a edelbrock 750 one inch.after asking what cam they put in it i took it out.they use a special grind with a 480-488 lift.they told me it isnt a choppy cam so i put in a compcam xe 268 all msd and a speed demon 650 hopefully it will be in before the summer is over.having a tpi you have to buy alot of parts
Car: 89 RS Camaro, Metallic Blue
Engine: 2.8 V6 (The 350's comin)
Blueprint Engines have been around for a while. I remember about 5 years ago I saw an advertisement for them on like the speed channal or something and looked on their website. I was amazed at the low prices of their engines but never really thought about them again until I saw them on Jegs.
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
I saw their poster while I was at Napa yesterday. I am still impressed with their price after reading what goes into them.
Car: 1985 Pontiac Trans Am
Engine: 305TPI
Anyone new info on these guys? Ive decided to skip the Pontiac motor swap and stick with a SBC. Looking at the Blueprint 405HP 383ci Vortec Heads(base model).
JEGS High Performance - Blueprint Engines 383ci SB-Chevy 405HP / 440TQ
Car: 88iroc
Axle/Gears: 373
blueprint engines
Car: 88iroc
Axle/Gears: 373
blueprint
How do you like? Which 355 base did you get? The Vortec 355?
Originally Posted by dwint
you would,nt believe it but it is still on my kitchen floor.you have to buy alot of parts and it runs into alot of money.i bought a speeddemon 650vs k&n filter headman lLt's hays flexplate msd ready to run distribuator balancer edelbrock alluminum reverse water pump and a 110 fuel pump.msd 8.5 wires bullet mufflers lokar cables e.t.c.it seems like i have had some hard luck trying to get this engine in because something always comes up.they say there cams run really smooth thats why i changed mine.comp cams says i will probably have more horse with my set up but who knows i just want to get the damn thing in already
Engine: 305TPI
lol. Ya, I believe it. The cam supposedly run smooth huh? I will have to call and to talk to these guys before I buy it. I dont a smooth cam, lol. Its going to be my daily driver(except in winter), but I want decent lope.
NinjaNife
08-23-2015 11:49 AM
