turbonator
Car: 89 trans am ws6
Engine: lb9 5.0
Transmission: 5spd
Axle/Gears: 3:09
turbonator
anybody heard of this turbonator thing that goes on after your air filter. I found this one on e-bay for $14. They claim up to 35hp and 31% better fuel mileage. any body have one? is it any good?
http://cgi.ebay.ca/ws/eBayISAPI.dll?...MakeTrack=true
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
You should have searched first. They are garbage. They physically cannot compress enough air to create real boost, and have been proven to actually REDUCE power due to the impeller blades restricting airflow. It's like trying to use a desk fan to make a hurricane wind go faster.
Engine: lb9 5.0
Transmission: 5spd
Axle/Gears: 3:09
ouch!
thanks, they won't get my13.95 now!
is there any "cheap" way to get a few more hp?
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
He's new, he's adding to the board post count, so get off his back and shove the "do a search" advice you know where. Whats the point of having an online message board. maybe the admins should make it an online search forum?
Transmission: 5 spd
1 Post
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
There are alot of things that make your car go v-room...lol
Some of these mods are free others cost alot of money.
The easiest thing, but very dangerous if you dont know what your doing is an
Ignition timing advance- by using higher grade fuels and advancing the timing of the ignition so that the spark plugs fire earlier than before you can pick up alot of power.. This is part of tuning an engine.
A cheap mod is a Throttlebody Air Foil, you pick a few hp and tq, mostly on the high end, but due to less turbulence in the intake passage the charge created by the TPI can be slightly more effective.
Another modification though slightly expensive is a new exhaust system. Sadly for these cars the only system really offered is a new cat back, or all the plumbing, mufflers and tips in the system.
If you dont have them already a set of dual catalytic convertors can free up a good few horsepower. In your case, which is the TPI 305 5spd car you are well set off. And unknowingly you bought one of the fastest V8 thirdgens built. The one thing that you could use is some rear gears. Though 3.08's are alright, a set of 3.42's or 3.45's will get you off the line quicker. (make sure they are posi!)
(on a side note before I get spammed, a TPI305 5spd. is the equivalent of an L98 in stock form.)
Another modification that is a pita to do, but does free up more horsepower and torque is long tube headers. In your case 1 5/8" primaries with a 3" collector. Make sure that they can the preparations for the AIR system, that they work with cats, have a 02 bung on the drivers side and if possible will hook up to dual cats if you decide to run that route..
Since you are a firebird and not an IROC-Z, your intake system detracts about 10hp from the actual ratings you have read on the facts page. So for a few hundred dollars pick up a cold air kit with a enclosed box(to keep out debris).
Later modifications, can be discussed, but this should definitely keep you busy for awhile. Note, your 19lbs per hour fuel injectors pulse out at 240hp, and your ecm will need a new prom if you decide to change these.. Wait for this modification!
You already have a Mass Air Flow sensor so constant computer tuning is not required..
The best thing for your car right now though, is a good tune up! Flush all fluids and change your plug wires and plugs, and rebuild your distributor! (Cap, Rotor, check your icm and if necessary your pick up coil,) Dont forget new filters, fuel, oil and air.. cleaning your egr/pcv will help as well.
There are alot more things you can do as well to make your car faster, but lets start with the basics before you touch the innerworkings of an engine. The best Idea to learn an engine is to get an old scrap 305, LG4, 350 etc. and just take it apart. leave your running engine alone.
Car: 81 Corvette
Engine: 355, ported vortec heads
Originally Posted by formula350sd
Dude you need to use the search function and browse around the forum there are years worth of tech info on this board that cover everything from restored stock street cars to 500= horsepower blower and turbo fed engines look around and learn how an engine works and opperates before you start trying to make it stronger
Originally Posted by 305q_ta86
Because now when the next person comes along and does a search, all they find are threads like this.
gon8go
Here you go.
https://www.thirdgen.org/forums/afte...ght=turbonator
This is the link for the article that is in that thread.
http://www.popularmechanics.com/auto...tml?page=1&c=y
Next time try a search first so you get answers instead of a thread full of people complaining how you didn't use a search instead of offering any real help.
1 Post
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Originally Posted by vrtc350
So by what you are saying no one should post anything new since it has already been covered in years worth of tech data?
Then why don't you help them out while suggesting the search instead of leaving this as a repetitive waste of band with and space? If you know where it is then give them a link for the next person who may actually do a search.
gon8go
Here you go.
gon8go
Here you go.
Car: '87 FIREGOOSE!!!!
Gon8go, welcome to thirdgen.org!
Always nice to see new members. While your here, make your way over to the "regions" section and go to "Ontario" board to introduce yourself.
Car: 89 Formula
I am in no way saying that posting of questions is bad but so is wasting bandwidth with a million and a half threads with vague questions like what should I buy for my car to make more horesepower performance isnt cheap but the best thing anyone could do as far as I'm concerned are full length headders and a 4 inch exhaust that was by far the best things I have ever gotten for my car
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Well a 4" exhaust is a huge overkill unless your making in excess of 400hp.
Maybe you should do a little searching yourself.
Car: 89 Formula
Car: 81 Corvette
..look around and learn how an engine works and opperates before you start trying to make it stronger
.. the bast advice to give anyone getting into the car hobby should be to laearn about engines simly slapping performance parts togeather will don nothing for him it needs to work as a system and if you don't know how an engine works how can you expect to get it right
.. so is wasting bandwidth with a million and a half threads with vague questions like what should I buy for my car to make more horesepower performance isnt cheap.
You must hate %80 of the threads on this board.
Car: 81 Corvette
I agree 100%. The turbonator is a piece of garbage.
I just find it annoying when people want to yell search instead of offering any help at all. Sure, we need to remind some of the search but it is more helpful to still point them in a direction rather than none at all.
It's funny how you see a lot of threads with "Before you tell me to do a search, I already did and didn't find the information I needed."
Car: 89 Formula
Damn, Formula, ever use periods? :P
Cheap is relative.
and as far as patronizing people i simply told him to read on engine physics something everyone in the car hobby should do as service to them selves not to me or anybody else
Originally Posted by Genopsyde
and it's kinda hard to do a search when it hasn't been working right for how long?
Engine: lb9 5.0
Transmission: 5spd
Axle/Gears: 3:09
this is great!
All this spirited debate is very entertaining so its hardly a waste of bandwidth since entertainment is a major reason why I signed on. thanks guys.
Car: 89 Formula
Engine: lb9 5.0
Transmission: 5spd
Axle/Gears: 3:09
no problem
normally I would do a search butI thought it was down.
I would love to get some headers and all but I just can't afford it now. I want to get the car wet sanded and replace the t-top centre molding and weather stripping. I'm addressing issues one at a time for now. thanks for everyone's help and patients.
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
All of the add ons that are suppose to "smooth" out air flow are totally worthless on cars with twin blade throttle bodies
wow I read through half of these postes and gave up. Too much whining about the whole search thingy.
Let me make this clear. The turbonater DID help reduce my gas consumption. It does have the same effect as an air foil too. I did dyno testing. I gained 2 whole horses. Wasnt even a noticeable gain but I did gain 3 mpg in the city and 5-7 mpg on the highway......using only the best and most expensive gas. I only did it b/c I was running VERY rich and I did a K&N air filter and it helped lower the a/f ratio. Then the turbonater was next and it lowered it a little more. Now ready for this one. I have a NX Expres wet kit and it is plumbed BEFORE the turbonater. Now can you imagine the swirling effect the my wet kit has when I spray going into my intake? Now try and swallow that
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
ok if it wasnt for the fact that I have dyno results i would have NOT posted that. So tell me then what is the difference between the "turbonator" and an air foil then...............oh thought so
Engine: LB9 & L98
The airfoil works in effect that it smooths out that flat surface where the air enters the throttle body. The turbonator DOES speed up air flow and creates a good swirl effect, but when this swirling air hits the throttle body opening and is split between the 2 throttle body blades, it cancels the "swirl" effect thus diminishing the effect the turbonator was intended to produce. The best results from the turbonator will be in a single blade throttle body setup, like the LS1 or a mustang... etc..
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
Be sure to stop by the Ontario Region board and say hello we would be glad to meet you.
RP
Car: 88 GTA
Engine: 383
Transmission: 700 r
Not to confuse the issue with facts, aren't fuel injected manifolds dry flow. I don't see the benifet fo "turbonating" dry air. By thr time ath air passes the fuel injector the effects would be nill.
