Don't buy Zenn lowering springs!
Car: '87 Camaro SC
Engine: 305 LG4
The fronts are starting to settle and look pretty good. The problem is the rear springs are too soft and drop the car down WAY too low. I had to put my old springs back on the rear. I may cut half a coil off the stock rear springs after the fronts settle to even things out. I bought these lowering springs on eBay after seeing good feedback from people that had bought the same ones for their Camaro. I guess they had not installed them yet!
They have an advertised drop of 1.7" front and rear. I would say it's more like 1.7" front and 3" rear. The ride was horrible with the rear springs on and made my car look like it was hauling bricks!
Car: '87 Camaro SC
Engine: 305 LG4
$120 shipped
Here's a pic of the before and after with Zenn springs on the front. It's been less than a week, so they may settle a little more.
Car: '87 Camaro SC
Engine: 305 LG4
I may try that later on, but right now I would rather not look at a spring for a while. Plus I need to see how low the front is going to settle before I try to get the rear right.
Car: '87 Camaro SC
Engine: 305 LG4
Originally posted by mw66nova
hmm...looks like a pretty clean sportcoupe you got going on there! plannin' on keepin' it a sportcoupe?
Car: '87 Camaro SC
Engine: 305 LG4
Originally posted by ssean92
im glad u posted this i almost bought those springs
I don't have any heavy stereo equipment in the back either. Here's what the rear Zenn springs look like compared to stock.
Car: '87 Camaro SC
Engine: 305 LG4
Originally posted by sully91rs
That looks thick enough to be a front spring .
Maybe they were too hard instead of too soft? It felt like I had a 2x4 in place of the spring and bounced all over the place like a lowrider. I'm pretty sure it was on the bumpstops though. When it warms up, I'll put the rear springs back on and take some more pictures to show how low they are.
Car: Black 92 Z28
Engine: 5.7
Transmission: Auto Unfortunately
Has any body else had issues with the Zenn springs. Bad or good, as I am looking at getting some new springs.
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
who installed the rears for you??? did you make sure the isolator went back in ontop of each spring??? maybe someone lost them before you owned the car....my firebird was missing one and i put it back in after i found one at the junk yard.
Car: '87 Camaro SC
Engine: 305 LG4
I installed them and both isolaters are there.
I like your car! That's the stance I want mine to have. Did you trim the bumpstops on yours? If so, how much?
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
"I like your car! That's the stance I want mine to have. Did you trim the bumpstops on yours? If so, how much?"
lol i took the bumpstops off of mine...
Car: '87 Camaro SC
Engine: 305 LG4
Re: Don't buy Zenn lowering springs!
Car: 84
Engine: 360 210 alumium heads
Transmission: th350 3600 stall w/shift kit
Axle/Gears: floater Ford 9" 4.56 full Lw spool
Badass355ciz28 NICE CAR
sailtexas186548
08-26-2015 03:32 PM
1988iroc350tpi
08-14-2015 07:52 PM
TA8487
08-11-2015 09:02 PM
