How accurate are dyno simulators?
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
I've got the Dyno2000 Engine Simulator on my computer. I want to know if anyone has any experience wiith this or similar desktop dyno programs and how accurate they are. I don't have a shop with a dyno around and just want to get a close estimate of what I've got.
I have DD2000 and dragstrip simulator, it seems fairly accurate especially if you have good info to put in such as head flow numbers. The part that seems not accurate is overcaming an engine or over carbing....it doesn't seem to simulate those conditions well. Bigger cams and bigger carbs seem to always make more power through the entire rpm band. Its a good tool to use in comparing combinations but be careful of certain parameters you enter.
the thing is basically a toy, and it won't really accurately simulate any engine thats out of the ordinary parameters
for instance, it won't even accept the I/O, I/C, and E/O, E/C numbers for my cam shaft.......and if you use the numbers it forces, its like 100hp too high.
its fun to play with, but thats about it
Car: projects.......
main thing is for any accuracy, you need head flow specs. - also, I don't like that it only uses advertised duration. @ .050 would make for much more accurate numbers. - If you have ALL the perameters, it seem spretty accurate. Out of three motors I've been able to simulate + put on a dyno once built, desktop was 5hp shy on 2, and 3 high on the other. - tune/air conditions can make more difference than that. - as for the bigger cam/bigger carb thing, it doesn't seem to really show what a carb/Tb change really does. - As for the cam though, I've had no problems. As soon as I started over camming, I started seeing the side effects. But, again, I have always had my proper head flow specs. Also, be sure you switch to the "table" chart and read the real numbers @ a given rpm.
because theres no way to account for port velocity or combustion chamber design....quench area etc.
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
was a 100hp off no matter how i fiddled with it, and i built the engine, and got the program later, so i knew ALL the numbers... no matter what i fiddled with in the program it was way off....
Car: 1989 Firebird
Engine: a monster
DD2003 is the better program, allows you to enter in a LOT more peramiters... cam duration is @.50 takes into account the Lifter Acceleration Rates, ramp angles, LSA, etc.
darwinprice
17
10-11-2015 11:51 PM
LT1Formula
10-08-2015 08:34 PM
WhteRbt
09-21-2015 09:48 AM
