Edelbrock Strut Tower Brace?
Car: 1991 RS Camaro
Engine: Jasper 355
Transmission: Stock
Anybody currently using the Edelbrock Sturt tower brace? Ive heard they work wonders on newer cars, but those being the two point type, such as on a fourth-gen. The three point harness type, might help tighten up the old RS, and I was wondering if it is worth the 130 bucks, and if its hard to install. Thanks!
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It is worth the $130. The quality is a bit sloppy but the performance difference is night and day. If you do not have sub frame connectors I would get them before you get the STB.
Car: 1991 RS Camaro
Engine: Jasper 355
Transmission: Stock
Well, I do have the 14 inch Edelbrock Open Air Element, with the K&N Air Filter assembly. Will it fit around this? Does it go under the filter pan, or around? The description of the product only says the A/C stuff must be on the passenger side. Which of course it is. If anyone can help me with this, Itd be greatly appreciated.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
anyone know about how much one of these bad boys weighs?
Car: 1991 RS Camaro
Engine: Jasper 355
Transmission: Stock
Hey Shifty, I LOVE your motor, sooo clean. I can barely see the rest of the car though, mind posting some for me? My RS is that same dark red, and Im currently trying to get it painted to its original glory, lol. Thanks for the help.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
If you could see the car now you would barf. I have it in a million pieces for my overhaul.
Check out the pics in my sig. Don't look at the wrecked pics too much.
Car: 1983 T/A
Engine: OUT (350 Block)
Transmission: 700-R4 sometimes
Axle/Gears: 3.23, moser 12 bolt >=3.73 someday
Whats the reason behind most of the sites saying 85 - 92, i have a 83 t/a witha carb, will it still fit? it appeared the same on the pic.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
1 Post
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
I've got one and it's great--good fit--like the extra mounting points compares to the 2 point type. However mine looks different than the one pictured in the post a couple above my post here. Mine, the main bar goes straight across--no jogs--maybe there is different types i am not aware of. I'm not sure mine wuld clear the big air cleaner if it went staight across, but I have TPI, actually TPIS mini-ram and there's so much room it's not even funny!
Lon
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by Apeiron
I thought it was the driver side A/C compressor it had problems with.
LT1Formula
10-08-2015 08:34 PM
