45 degree Flaring Tool
I have a 45 degree Flaring Tool from sears ($16.99) which is exactly the same to the one on summit racing one (part number - 900310)
I was practicing my first flares and the line kept on getting pushed out. So I kept on tightening more and more, but it kept on getting pushed out when I went to flare it. Until....it the bolt/rod broke. So I was wondering if I just happened to get one with bad bolts or maybe I am doing something wrong? I was trying to do the 1/4 brake line, cut it, cleaned it up, put it in(exposing proper amount) and when I tighten the adapter it just pushed it out, (same with flaring bit)
Thanks for any thoughts...
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What metal are the brake lines? Those tools are usually for soft lines, like copper or aluminum.
Car: Trans Am
I know exactly what's happening to you. I tried to flare my own brake lines (the stock ones that are about as hard as diamond) with a cheap tool like that, and you just can't do it. The lines kept getting pushed out, and I even tried putting duct tape and sand paper in there to keep it in, but it just crushed the tube. I took it to my mechanic/builder, and he had some $500 flaring tool that made short work of it.
Long story short, find someone with a better tool.
:sigh:
how much was it for the guy to flare it for you...I need one stupid flare...but now I am thinking of just buying one of those pre flared lines online.
/and yeah Apeiron its the stock steal line thats harder then a diamond.
/thanks for the help
RedLeader289
05-28-2019 01:47 PM
