Electric Supercharger
Car: 1983 Firebird
Engine: 2.8L-5.0 swap
Transmission: T-5 5 speed
I saw this thing on ebay that is basicly an electric fan that is installed on the intake and was wondering if this would actualy give you any horsepower. Now I know that it wouldn't even come close to a $2000 supercharger but it claims to give double digit horsepower and torque increase with 2.1 psi for $140. The principle of it seems like it could work like a ram air system but I'm just not sure that an electric fan can spin fast enough to make even a small difference. I think it is just a scam but thought i'd ask anyways. Anyone tried something like this? Here is the link:
http://cgi.ebay.com/ebaymotors/ws/eB...949742187&rd=1
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
I don't doubt it wouldn't produce boost, I just don't think it could flow enough air to be worth $140. I wouldn't be surprised if you got around 20hp though.
1 Post
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
If you got it close enough to the throttle body, and it actually created + pressure, sure you would see a gain
Car: '82 Camaro
Engine: 383
Transmission: TH-350
Can you say scam? That is hilarious though. Look and those "high voltage" wires coming out of it! That thing claims it can flow 500 cfm...oh my! Wait...my carb is 750 cfm though...so basically I'd pay $140 to restrict my intake. Sounds like a plan! Look at that beefy motor! Most electric cooling fan motors would dwarf that. And if those would work for superchargers, everyone would be doing it!
My sarcasm is directed at the people selling (and buying) that crap, not to the poster.
Car: 1984 z28
Engine: BBC
Transmission: TH400
the so called electric 'supercharger' is actually a cheap boat part which people market for cars. It works for a little bit, even though it throw hot air into the engine. Once the engine gets close to full throttle the engine requires more air then the 'superhcarger' can put out so the engine loses power towards the top end while gaining a little at low end.
Best scam on ebay.
Best scam on ebay.
stupidest thing ever.........any oxygen thief that buys that should self terminate
That thing is going to cause a loss of HP due to airway restriction. Im sure people are buying them though. The tuners will be calling it "internal supercharging" or some such nonsense.
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Just read the guys feedback. I would decline the offer.
Car: 91 Camaro RS
Engine: TBI
Trust me, stay away from it, back in the days when i was with avalanche motorsports it was a hot item for the import guys, problem is there were alot of problems from guys that got em having pieces break off and go into the motor, i have pulled apart top ends on quite a few **** burners to get chunks of plastic out of em from those things. Not fun
Car: 89 GTA
Engine: 350 tpi
There was another post i just read about this the ebay ones are junk, however there is a guy who spent years trying to perfect an electric supercharger and he finally came up with a tri motor electric supercharger that did produce some hp gain. But if your looking into the ebay electric blower you might as well hook a leave blower to it you will probably get the same results...jack sh8t
Car: 88 GTA
Due to the dynamics of the fluid ( air ) and the magnitude and velocity of the air, this Fan supercharger could never spin fast enough to produce boost that could be used. Instead it will be a restriction if it is inline with normal intake flow because of the reduced volume for air to flow through.
Summary: Just a waste of time and money
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
Yeah, this has been covered already take a look at this, here's some hard facts: https://www.thirdgen.org/techbb2/sho...hreadid=229088
1 Post
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
His were also $4,000, only worked small displacement motors and would require a second battery. Nothing of the sort will work on a v8. They'd also drain the batteries far too much when at WOT so you had to wait a bit to let the batteries charge. So boost wasn't always just a pedal to the metal away.
They were pretty cool thought, he had dyno graphs showing over 170 + more hp on a some volkswagon engine. Once again, it was only for the four banger crowd and still cost as much as a centrifugal charger.
T: What size engine will this work on?
TK: Testing has shown the smaller the engine, the higher the sustainable boost. If a 3.5-liter engine is running 24v, boost will peak at 10 psi at 2000 rpm and then drop off to 3 psi at 6500 rpm. A 1750cc engine would make 10 psi at 4000 rpm while dropping off to 3 psi at 13,000 rpm. The boost drop is linear, so that 1750cc engine would make 7-8 psi at redline, and launch at 15 psi using 24 volts. If a blow-off valve is used to bleed off excess pressure, a steady sustainable boost is possible until the capacity of the supercharger is reached. This means that a prepared 1.6-liter four-cylinder can run a sustained 15 psi at 36 volts to 6000 rpm.
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i wonder if you can reverse the flow on thoese fans to create a vaccum. my hoover vac just died and i am looking for a replacement dont waste your time and money on that junk.
Car: 1991 Camaro *RIP* 1984 MonteCarloSS 1972 Nova
Engine: 355 cid 383 cid
Transmission: TH350 TH350
Cool little write up i saw on another fourm http://forums.s-series.org/viewtopic.php?t=28443
TMZIrocZ350
10-07-2015 12:09 PM
