Inland Empire Driveshaft ?
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Anyone running one of these? did a search on it and came up with ziltch
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
I put one in when I did the TKO swap. Been there for a few years now - no problems. Did you have a question?
-Schultzy
-Schultzy
I was wondering if they were worth the $ over the LS1 shafts and if anyone had vibration problems, and I seen one for 200 in the classifieds
Car: 1989 GTA
Sorry bud, can't help you on that one. I also have friends running the LS1 driveshaft with no vibrations/no problems. Maybe someone else with experience will chime in.
-Schultzy
-Schultzy
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I got one from them for my 68 bird no probelms with it fit perfectly and so far seems to be able to handle the 455's power.
Car: 2 1990 IROC-Z Camaros, 2000 WS6 TransAm RAM-AIR, Honda Civic & Cougar (daily drivers)
Engine: supercharged 383 TPI, 5.7 TPI, 5.7 LS1, 1.6, & supercharged 3.8
Transmission: 5 autos
I had one that I purchased through Summit, and had to send it back. It had a leaky seal and I was mad, so I sent it back and went with another brand......I also had problems with vibration above 50mph.....I hated that.........
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
Do you mean that 1 of the U-joint seals was bad???
BINGO.................In my opinion, its not a well built driveshaft
I think I`ll try a LS1 shaft, Thanks for your opinions guys
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
I ordered a dennys HD aluminum driveshaft and it cured my vib problems. Very well built and denny was great to talk too over the phone.
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
topteam54
10-06-2015 12:21 AM
