Air/Fuel ratio gauge
Car: 1991 camaro RS
Engine: 305 Carb
I was curious on how one of these works. I am going to switch my TBI over to a carberated setup, and i was wondering if i do this if i would still be able to use a air/fuel gauge? I know you hook it up to the O2 sensor, but not sure on the rest.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Nothing to it, three wires on the gauge itself: power, ground and sensor. Two more for the backlight.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by del91_305
But if you dont have a computer do you still have an O2 sensor?
Car: projects.......
I run one. Nice to have, deffintely helps you tune a carb. I wouldn't use it to fine tune from, thats what spark plugs are for. helps you get close though, and helps you check part throttle and cruising situations. Mine's running a regular Bosch single wire O2. My plugs are tan colored, and when I mash the throttle, the guage will "fan" out across stoich. I like it...
later, justin...
later, justin...
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by Apeiron
"Fan out" across stoich?
Car: 1991 camaro RS
Engine: 305 Carb
No. Well you could have one but it wouldn't serve any function. By going to a non computer controlled set-up your car is no longer using any closed loop feed back. I would use a more accurate 02 then a single wire. They are horribly inaccurate and your gage is pretty much useless. I have been running the autometer AF gage for a few years now. Little did I know.
![Confused](https://www.thirdgen.org/forums/images/smilies/confused.gif)
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Now im confused, one of you say that it wont wok, but the other says it does work with a carb. Maybe if i switch to carb i have to keep my computer?
Engine: 383 Carb
Transmission: 4L60
Originally posted by ShiftyCapone
Single wire 02's are useless to determine actual AF ratios.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Have an Edelbrock AF meter on my old Camaro. Seems to work pretty darn good. Really have the carb dialed in, but it's a lot of work to get it right. Big improvement in gas mileage and note some performance help too. Well worth the money in my opinion.
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
My Auto Meter A/F gauge #3375 instructions call for a single-wire O2 sensor like a Bosch 12014. It specifically says it is not designed to operate with a wide-band sensor. You can use a heated one, though.
If you are converting from a TBI system to carb just leave the o2 sensor in and use it with the gauge only.
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
O2 sensors are about emissions, and fuel economy not performance they're needed because catalytic converters work best when the mixture varies between lean and rich every few seconds.
A Wide-band 02 sensor would certainly help reduce the amount time it take to tune a carb although most gearheads I know say they can tune it faster by ear, my hearing is very bad.
That's why I like EFI, but unfortunely I'm required to pass emissions.
Engine: 383 Carb
Transmission: 4L60
It's not so much a question of the mixture needing to change every few seconds, it's that narrowband sensors respond so slowly.
Car: 89IROC
Engine: Forged 355 AFR195
Transmission: 700R4 Vigilante Converter
Axle/Gears: Strange 12 bolt 3.73
agreed with whats been said here. I wouldn't get one again. I'd take mine out if it wasn't such a pain...and I'm on boost. Innacurate and the further the sensor is away from the combustion chamber more innacurate it becomes.
Engine: 383 Carb
Transmission: 4L60
Right, the response of a narrowband sensor changes greatly with temperature at the rich and lean ends.
Hotrodboba400
12-10-2019 07:07 PM
83 Crossfire TA
09-18-2015 12:01 PM
83 Crossfire TA
09-08-2015 12:06 PM
